Arrived today, so I ducked that problem. This light will get a lot of use! Thanks again to the team
My mini’s arrived today. Excellent little lantern.
I am very pleased.
There was a seller on eBay that sold base for the LT1, maybe he’ll make some for the mini. Very reasonable price.
Light arrived, looks nice. Guess I’ll have to break out the 3d printer and laptop to see if I can design a wider base for it, if no one else hasn’t designed one yet.
Just opened mine, very impressed and pleased with it.
Thanks to all involved.
I just sent a note to the guy who did my LT1 base, on treatstock
Does anyone know if there’s a review video yet ?
Working on it
Just opened mine, impressive light for the size/weight. But I seem to be messing something up when I’m trying to finish my setup:
7 clicks when in standby in advanced mode should let me change the standby button leds from blinking to off, right? I know I’m in advanced mode since I can change from smooth to stepped ramping and I know I’m in standby, but I can’t get the standby button leds to change.
It sounds like you’re doing it correctly. Run back through it once more.
Ensure you’re in advanced mode by clicking 10x, holding the last click, and continuing to hold it until the light stays off for more than 1 second.
Enter lockout mode by clicking 4x. It should blink to confirm the change.
Now click 7x to change the switch LED mode. The modes are blinking, off, low, and high.
Following these steps allows me to change the swith LED behavior in lockout on my sample, so I don’t think it’s a firmware bug.
beech18650:Just opened mine, impressive light for the size/weight. But I seem to be messing something up when I’m trying to finish my setup:
I follow those steps, and I even get a double blink of the button after 7 clicks, but it’s staying in what I think is blinking mode. It will keep doing one dim blink, then a bright blink, then repeat that pattern. Is that some different indicator function, or is that the pattern for blinking mode?
That is the pattern for blinking mode. There is no other indicating function for the button LED built into Anduril.
Can you successfully change the button LED behavior when the light is NOT in lockout mode?
And just to be totally sure, we’re talking about the orange button LED’s, correct? Not the blue button LED’s.
beech18650:I follow those steps, and I even get a double blink of the button after 7 clicks, but it’s staying in what I think is blinking mode. It will keep doing one dim blink, then a bright blink, then repeat that pattern. Is that some different indicator function, or is that the pattern for blinking mode?
Correct, we’re talking about the orange button LED.
So I hadn’t tried to change the standby mode LEDs since I prefer to keep those on high and lockout set to off, but I just tried it now and I can’t change standby LEDs away from high. I did verify that I was in advanced mode by switching ramped to stepped before I tried to change standby LEDs.
tactical_grizzly: beech18650:I follow those steps, and I even get a double blink of the button after 7 clicks, but it’s staying in what I think is blinking mode. It will keep doing one dim blink, then a bright blink, then repeat that pattern. Is that some different indicator function, or is that the pattern for blinking mode?
I just tested my LT1 Mini and it will allow me to switch between stepped and smooth ramping EVEN IN THE SIMPLE UI, which none of my other lights will do. That makes me think that you may actually be in the simple UI. Just one more time, try clicking 10x from off and holding the last click. Then try changing the switch LED settings.
beech18650: tactical_grizzly: beech18650:I follow those steps, and I even get a double blink of the button after 7 clicks, but it’s staying in what I think is blinking mode. It will keep doing one dim blink, then a bright blink, then repeat that pattern. Is that some different indicator function, or is that the pattern for blinking mode?
Thank you so much, that was it. I should have paid more attention to the user manual and realized that ramp options were still available in simple…
Great job DBSar , Sigshooter & Team - I put my order in and they shipped it already it seems.
Not the longest thing I have waited for lately, but close…
This this an identical UI to the LT1?
I also cannot seem to change the led standby colour
Yes, but not the latest according to the review posted a few pages back
It’s worth noting that mine came with firmware version 2021-08-29-0621, so it’s missing some of the latest features like instant-switching and 200% turbo.
UI should be indentical:
Andruil Manual
That’s normal. The switch LED’s are not RGB, they are orange only.
leftfordead:I also cannot seem to change the led standby colour
mine flicks between orange and blue when charging and solid blue when full
orange when on standby
