Happy Birthday Simon!
Have a great day, cheers!
Happy Birthday, Simon!
Happy birthday Simon! Thanks for your continued interaction with us. It is greatly appreciated.
I didn’t know the regulator was linear, touché. Still, worst case is 4 - 6A draw per cell. Voltage sag may still be the culprit, but well within the cells’ capabilities. Only way to know for sure would be to test with different cells and compare I suppose.
About 70~80mV higher with 30Q at 5A at high SOC, not a big difference but it can help a bit.
More importantly the 180mV drop across the sense resistor doesn’t help.
With 30Qs and a more reasonable 50mV Vsense, 0.2V would be saved, that’s significant.
Simon,
I want see which of these drivers is less bright.
Can you post a photo comparison between the13 group driver powered by Ni-Mh AA batt.4.0€ 53% OFF|AA / 14500 / 16340 fahrer für T2 T3,13 gruppen|Taschenlampen| - AliExpress
and the 4x7135 new firmware driver powered by lithium?
Page Not Found - Aliexpress.com
Both drivers set at minimum level brightness with same Led type
Thanks
7135*4 is out of stock
Happy Birthday Simon Mao……Wishing you the biggest birthday celebration today, good health and more flashlights to build.
Although today is not my birthday, I still want to thank you all. :partying_face:
There’s an interesting thing in there. China has a lunar calendar and a solar calendar. Actually my birthday is counted according to the lunar calendar.
When will the 23.2*1.4mm ar-coated glass lens ,suitable for Convoy S21A S21B be available with the new green AR coating?
Some use new green coated lenses.
NeutralFan:When will the 23.2*1.4mm ar-coated glass lens ,suitable for Convoy S21A S21B be available with the new green AR coating?
Excellent, I’ll add the lens to my order!
Simon, is there any chance of adding additional colors to the standard anodized aluminum S2+? It would be great to see a yellow one.
Yellow doesn’t look very flattering
Titanium alloy T4
primarycolorsnomore:Simon, is there any chance of adding additional colors to the standard anodized aluminum S2+? It would be great to see a yellow one.
Hey that’s my favorite color!
I understand though if it’s not worth it to manufacture since there wont be enough demand.
Do you have an estimate of when the MAO version will be available?
Titanium alloy T4
Wow. That’s gorgeous! What else is coming in Ti?
He mentioned that it would be 3-4 weeks about 2 weeks ago. So hopefully 1-2 more weeks if there are no delays.
Oh that titanium looks beautiful! Better make plenty of those ahead of the Christmas gift season.
Titanium alloy T4 !https://live.staticflickr.com/65535/52223657236_e03005b8cb_b.jpg!
Great looking!
Now we need S2+ and T3 in Titanium
You can bake a grey. The end result looks quite yellow in the photo. I’ve only ever baked black, and that wasn’t Convoy either.
I would describe end result of baking grey ones as silverish golden or other way around. If I remember right it turns more silver the longer it’s baked.
