LG INR21700-M58T (5570 mAh)
21 posts / 0 new
Pajda cz
Last seen: 10 hours 31 min ago
Finally cell which can beat a mythical 800 Wh/l in cylidrical format?
I found this cell on Nkon store https://eu.nkon.nl/rechargeable/li-ion/21700-20700-size/lg-inr21700-m58t... only other source which listed this cell is EVVA http://evva-tech.com/plus/view.php?aid=329&tid=3
Ordered samples from Nkon, I will start cycle life and other tests as soon as it arrives.
FlashPilot
FlashPilot's picture
Last seen: 1 day 4 hours ago
Im looking forward to your results. Hopefully voltage wont sag too much while under moderate loads. I suspect cycle life will be considerably shorter than most name brand lower capacity cells.
BlueSwordM
BlueSwordM's picture
Last seen: 2 hours 27 min ago
Wait wait wait.
At rated capacity, this is 280Wh/kg, and at minimum capacity, it is 270Wh/kg.
I’ve seen semi-custom form factors reach 300Wh/kg without taking into account lower packaging efficiency(which is functionally the highest with cylindrical cells), so this is impressive.
I wonder what is different about it at the chemistry level.
Pajda cz
Some photos of M58T samples from Nkon. It can be seen that cells were removed from modules, but the welds are nicely cleaned. An interesting feature is the use of a one-side busbar connection in that app, I guess laser was used for welding. The dark circle in the middle of the positive terminal is probably caused by the laser as some surface treatment.
I hope to have first test results today.
man of light
man of light's picture
Last seen: 10 hours 11 min ago
Can you check the actual dimensions and post them here? Diameter, length, etc. Because according to the information from NKON and EVVA, it looks like this cell is a bit larger than the usual standard and I’m wondering if it will fit in some of my light where it was a tight fit.
EVVA states 21.80×71.0mm and NKON 21.3×71.0mm.
tiry31
Last seen: 2 months 3 days ago
Look at the end of Nkon’s page
Nkon
Quote:
Note: Even when charging with 5,000 mA within the described limits above, continuously repeated cycles are not preferred. If the cycles exceeds 10 times, performance and safety cannot be guaranteed
Performance I understand, but safety ?
BlueSwordM
The one possibility for why safety is an issue is that LG likely found a way to increase the thickness of the electrodes through an innovation internally, but without finding a way to offset the internal resistance loss of such a change.
That would mean the cell gets hotter, losing more cycles, and all of the usual stuff during charging, and they don’t want warranty claims because of that.
Oli
Last seen: 3 days 56 min ago
It looks like a very thin positive terminal that’s already bent/ pushed down near the lower left leg in the picture. Flat tops of many cells are not really designed to be abused and or dropped in flashlights even with springs in both ends.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
Pajda cz
So first results added to the comparison here: https://endless-sphere.com/forums/viewtopic.php?f=14&t=114486
Unfortunately, due to the declared larger dimensions D: 21.7 mm and H: 71 mm, the volumetric energy density is only 768 Wh/l and therefore the “magic” value of 800 Wh/l in cylindrical format still resists. Sad
Pajda cz
I can do measurement and weighing on Monday at first. The EVVA dimensions are max. limit values delcared by LG. It seems that Nkon samples used a thicker tube than LG original tube.
Pajda cz
Actual dimensions of Nkon sample:
with tube: D: 21.6 mm, H: 71.2 mm, Weight: 71.8 g (Nkon transparent tube)
without tube: D: 21.4 mm, H: 70.5 mm, Weight: 70.8 g (this cell have an elevated positive terminal)
So without tube and with 20.3 Wh as measured nominal 0.2C energy it makes exactly 800 Wh/l Smile
Hoop
Hoop's picture
Last seen: 2 hours 23 min ago
Exciting stuff. Thanks for testing it Pajda. This cell probably can’t be stuffed into an S21A it’s so fat.
tactical_grizzly
tactical_grizzly's picture
Last seen: 3 hours 13 min ago
I measured 5700mah from the cell included with my Sofirn LT1 Mini using a SKYRC MC3000. I wonder if they used this cell and rewrapped it. The positive contact looks to be the same shape. https://tgreviews.com/2022/06/30/blf-lt1-mini/#batteries
man of light
Thanks for the shared measurements, that looks interesting to me, I’ll order a few.
BlueSwordM
I’d only buy the cell if you were planning not to draw more than 3A TBH.
Pajda cz
Quote:
LG INR21700 M58T (5570 mAh) updated data after first 50 cycles. I have added the data of two more cycles after 50th nominal to show that we will be observing a decent “sawtooth” trend. I’m not surprised by the behavior that cell does not like cycling at lower charging voltages, I’ve just never seen it this strong within LG production. Next to this 95% DoD test (4.15-3.00V) the standard 100% DoD test (4.20-2.50V) runs in parallel and here the cycle life looks very good so far.
You can also check a new thread about simple calendar ageing test results of modern cylindrical cells here: https://endless-sphere.com/forums/viewtopic.php?f=14&t=117028
BlueSwordM
Anyway, here’s the 1st product that actually seems to use the M58T:
https://youtu.be/-exET7wFWWk
I just searched for LG M58T on Youtube, and found this Silly
BlueSwordM
Also, the M58T’s energy density is quite impressive.
285Wh/kg is nothing to sneeze at.
vapcell Dennis
vapcell Dennis's picture
Last seen: 3 hours 39 min ago
![img]https://i.imgur.com/yaOuzFq.jpg[/img]!
Hello, are the M58 21700 batteries of nkon disassembled from the equipment? Or is there a brand-new M58 without welding marks?
Pajda cz
Dissasembled, Nkon says “These batteries are from a canceled car project”. Brand new M58T cells comes in standard LG tube.
vapcell Dennis
Dissasembled, Nkon says “These batteries are from a canceled car project”. Brand new M58T cells comes in standard LG tube. !{width:50%}http://evva-tech.com/uploads/220519/1-2205191T32O48.png !
Thank you for your information sharing
It may be that large brands of cars are testing the use of batteries, such as Porsche, Mercedes Benz, etc
