Why do the new power supplies for RD6006 have only 3 capacitors?
The older ones had 4
hello, are you sure RD6006 has 4 capacitors? becasue I check the original design, it only has 3 big capacitors, do you mean other models? or you can show us the picture
I saw 3 capacitors
RD6012P feedback
ordered RD6012PW whole set, delivered in good condition
https://www.aliexpress.com/item/1005003472332331.html
No, I mean on the power supply, not on the controller board.
There are 4 in the video
for this, I do not know, because the input PSU is not produced by us, we order them from another manufacturer to work together with our RD power supply, anyway, it does not affect the performance
RD6006PW feedback
The block works great. I recommend the seller Good quality
http://aliexpress.com/item/3256801999408137.html
RD6012P feedback
Great product and great seller. Very happy. I have also had an RD6018w for well over a year and has been nothing but brilliant. Hopefully this one is the same. It is fairly simple to set up, everything that is need is included.
https://aliexpress.com/item/1005003472332331.html
hello, for the input PSU chosen for our RD power supply, please notice the output, make sure it is below 70V DC and stable, then it is OK, and for the feedback, do not include your address information, it is not safe
https://rdtech.aliexpress.com/store/923042
RD6012P feedback
great device. I liked.
RD6024 feedback
Very happy with the product. Device very well mounted and working normally
https://aliexpress.com/item/1005003744641750.html
RD6012P feedback
good, if the range can be switched then it would be perfect.
RD6024 feedback
Thanks for the present.
RD6024 feedback
I bought it for the second time, the packaging is very good, the quality of the power supply is very good, the adjustment is relatively simple, the screen display is clear, and it is exactly the same as the seller's description.
hello, if you have interest and spare time, you can have a look at our Alibaba live
https://www.alibaba.com/live/rd-tech-products-introduction_54005b91-e3e7-4b34-8fe0-ad246584acce.html?referrer=SellerCopy
RD6012 feedback
take 10 minutes to finish the assembly, it is good
https://www.aliexpress.com/item/2255800866885424.html
RD6006P feedback
Great converter, it’s a pity that I didn’t take the 6012p version
https://www.aliexpress.com/item/3256801999408137.html
RD6018W feedback
Power supply works well and fitted perfectly in the case. I'm very happy with it.
https://aliexpress.com/item/1005001488070904.html
RD6024 feedback
the device comes in 2 weeks, and everything works
