Yeah, I always compare overly-roasted coffee as “tasting like an ashtray”.
I once made the mistake of getting oily beans. Vile. Clogged up my grinder and made it a beeyotch to clean. Was glad when I choked down the last of it and got new.
Everything I’ve read thus far points to never freezing… because the extreme cold sucks moisture out of the beans, and that’s the last thing you want to happen.
Well said. Roasting coffee is just a special case of roasting anything that contains proteins and sugars. As you raise the temperature you’ll progress through drying, Maillard reactions, caramelization, carbonization, and ultimately combustion. I think of City roast as being dominated by origin and Maillard flavors, Full City to Vienna as increasingly dominated by caramelization, and French and Italian as being progressively ruined by carbonization. By the full carbonization stage, all bean character is lost — it’s literally just charcoal.
Starbucks is notorious for over-roasting their beans. “Dark roast” inherently requires more roasting, but most of the time it seems companies do it too long… and hence, the oily sheen that you mention.
It’s like somehow most people got the idea that the darker the roast, the “richer and more potent” the coffee. And this just isn’t the case. You can brew a strong coffee from medium roasted beans. I’ve also found that medium roast just tastes better, after some trial and error buying. The logic seems to fit — you roast to a medium darkness and you don’t lose the quality characteristics of the beans, a flavorful and appealing taste. Dark roast goes too far. It can smell more intense, but in taste it’s almost always bitter… requiring sugar and milk to temper it, make up for what’s lost.
The absolute best coffee should be so good that you would only want to drink it black. Next, for coffee that’s a little bitter, adding milk softens it. And then finally dark roasted coffee that’s bitter & acidic requires also adding sugar. That has been one of the “litmus tests” for me—if all I need to do is add milk for the coffee to taste good, then it’s decent. I’m really eager to get to that point where even milk isn’t necessary.
I think this “darker = richer” association is due to the fact that a bag of dark-roasted beans has a stronger smell than a bag of light-roasted beans, due to the flavorful oils being pushed out to the surface of the bean. But this doesn’t translate to the brewed cup, which is all that really matters.
How refined are you taste buds? I've been freezing beans for years now in 5lb increments. Only issue is when I get certain beans, but most do fine in the freezer. Also, some beans require resting on arrival before freezing.
If you have the option not to freeze (buy/roast small batches), then an air-tight container works very well.
They say oxidation is the enemy of freshness. Chemical reactions slow down with lower temp. The reasons not to freeze never made sense to me. I’ve tried freezing, it works.
Totally agree. Freezing works. Fruits & vegetables, on the other hand, would be a no, unless they're going to be made into smoothies/soups. Freezing them changes the texture :-)
I don’t know the answer to freezing, but I do know that a lot of the negative mentions of it in articles don’t make clear that they are talking about putting it back and forth in the freezer as you use it.
I freeze it in the unopened original package plus a freezer bag to prevent punctures, until it is time to start using it, then I keep it in a tight jar, and I don’t know why that would be worse than leaving it on the shelf for many months or a year.
That article describes what I do, it starts with the advice against storing the coffee in the freezer between uses and then way down in the article it points out that freezing the unopened bulk purchase is fine in the freezer until use (time before use counts though).
regarding freezing intact
and not-ground BEANS…
this is what i have so far:
1. freezing is fine IF they are frozen ONCE and thawed ONCE.
2. freezing is fine IF the beans are protected in some way.
3. freezing is fine IF taste is not the overriding concern.
The bottom line is that lower temperatures do slow the staling process. Coffee also has incredible ability to absorb odors so I don’t mess around with any bag containers. I use only sealed mason jars for storage.
I generally roast every 7-10 days so I don’t worry about temperature and aging. But I do notice a difference between summer and winter during those 7-10 days! I have frozen beans (in sealed mason jars) if I will be out of town and need a stash to last a few days when I get home. It’s better than leaving for week(s) at room temperature.
IMO 18+ year green bean roasting experience, I’ve noticed that at about 14 months, in sealed poly bags, beans started to turn a ‘straw color.’ But who knows how long that they were sitting at the merchant?
They still roasted fine, but one has to do a lot of experimentation to truly determine any degradation and I’m not that hardcore.
The staling chemistry process for green vs roasted is entirely different. To be conservative I would say the green beans will last at least a year… but there are exceptions; mostly dry process beans can fade in their more subtle flavor character.
Roasted beans have expanded by 50-70% in volume, opening the cell structure to oxidizing and the oils are more exposed as well.
Roasting coffee is nothing less than a complete transformation of the bean. To demonstrate this, try grinding and brewing coffee with green beans!
1. green coffee beans which have been frozen for at least 6 months. then thawed. roasted. ground. brewed. what would you expect to be the outcome?
2. roasted beans frozen for 6 months. thawed. ground……etc.
3. ground beans……etc.
really, just curious.
although i do not drink coffee,
friends and relatives do and i would
like to have something they would like
to drink when they arrive unannounced.
easy as possible and flavorable as necessary.
We can talk about the voodoo behind home roasting, but if you do roast, do a batch, wait 24-36 hours in a sealed glass jar and then grind what you might prepare for over 1-2 days and just repeat the process until you’re out of roasted coffee, starting again.
