Damned… came in on this a couple days late. Coupon seems to no longer work, or you must be a PRIME member to enjoy the discount. :person_facepalming:
EDIT: I was selecting the black model, which is a few bucks cheaper. But it appears the discount coupon works only on the colored ones. Still, very good deal. Got a green one.
Geeez I thought you had ‘My’ keys for a second……… what’s that scary skull key to?
I havent had a problem with the usb cover however I bought mostly to use the clip on a pocket or backwards cap but the clip comes loose REAL easy and it would be REAL easy to lose the light if it was not being used. I will probably glue the clip……… :person_facepalming:
Agreed regarding the clip. Silicone “C” cover is the worst I’ve seen to date. No lock out is a bummer as well. Not very well thought out by Wuben all around.
Good deal at this price point for a utility side light.
PREPPER’S SURVIVAL BIBLE : The Complete Life-Savings Guide to Stockpile, Home-Defense and be Completely Self-Sufficient and Survive to the Worst Scenario ever Kindle Edition https://www.amazon.com/dp/B09ZT2WS1X
WUBEN L50 Rechargeable LED Flashlight 1200 Lumen, Super Bright Tactical Flashlights, 5 Modes, Waterproof IPX8, Portable USB Flashlight Suitable for Outdoor Survival, Camping, Search and Rescue, Home
$38.99 Prime and a 50% off coupon
Save 50% on the current price above with promo code 50Q7XXDG, expires 8/17 while supplies last.
ENERGIZER LED Flashlight, Bright Mini EDC Flash Light, IPX4 Water Resistant Flashlights for Camping, Outdoor, Emergency Power Outage (Batteries Included)
Just received this today. Not very bright, but I admit I like this light. Pretty thick plastic body, simple UI, press for high, press again for low, press again for Off. Hold down side switch for strobe. Strobe can
be activated when light is off simply by holding down the switch. The acrylic lens was a bit foggy, so I removed it to clean it. Figured while it’s off, may as well take a peak inside. Seems well built for this type
of light, very nice soldering and neat. After I test in outside, I may, just may unscrew the board and take a look at the batteries. The rear of the reflector does have a mild heat-sink attached. But I doubt it’ll be needed for a low power light such as this. Just a couple of internal photos below.
