For Sale: Price Reduction - Megaray MR175, 175 Watt Short Arc Beast
6 posts / 0 new
BVH
BVH's picture
Last seen: 2 weeks 4 days ago
The MegaRay – Megaray SOLD $499 Plus $25.00 shipping CONUS
Up for sale is my 175 Watt Megaray MR175 with custom Carbon Fiber and Aluminum battery carrier mounted on the bottom. I used two each, 4-cell, 4000 mah Lipo batterys wired in Series (input voltage is maxed at 30VDC) to power the light. This tube is removable and you can modify the cord to connect to any battery system. IIRC, I could get about 30-35 minutes on a charge. In a comparison post in a thread I made on CPF, the MegaRay hotspot in candlepower is a fraction less than my Gen3 Maxabeam, however, the hotspot is about 2-3 times larger so it is easier to actually identify what the target is V the Maxabeam. There is no carry case. I retrofitted this light with a higher CFM and lower noise level cooling fan. The light is in Excellent condition.
(edited)_MegaRay_1(1)
(edited)_MegaRay_2
WWII 60" Carbon Arc (Sold), 1.6KW NightSun, 1KW VSS-3A, .8KW TrakkaBeam, 600W M-134 Light, PolarLi 500 Watt 114MCP Custom, 500W X-500-14s, 500W Starburst, 500W A120b, 450 Watt AEG German Leopard 1 Tank Light, Enderman CFT-90 Syniosbeam, 300W Locators, Megaray (sold), 150W Communicator, Maxabeam Gen3 (sold), Pichel 75W Mini-Novas
Edited by: BVH on 08/22/2022 - 20:17
Hoop
Hoop's picture
Last seen: 47 min 8 sec ago
Talk about a rare duck. It puts a smile on my face seeing that LK14 for sale. One of the regulated ones too. KuanR over on CPF mentioned he wanted one just a few weeks ago.
BVH
BVH's picture
Price reduction on Megaray
ArtieT59
ArtieT59's picture
Last seen: 9 hours 2 min ago
Interest is peaked in this LarryK14, do you have a beam shot?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
BVH
BVH's picture
Yes, the building of and then some beamshots in post # 8 here:
https://www.candlepowerforums.com/threads/new-lease-on-life-for-larryk14...
BVH
BVH's picture
Are there no “Hot Wire” enthusiasts left. This is the ultimate Hot Wire at 650 Watts! Full soft-start, regulated 30 Volt, 22 Amps brightness until Low Voltage Cutoff occurs before which you get a dimming notification and nobody would ever suspect the light cannon you have in your hands. The squeal of the FET’s adds to the drama.
