It’s not, it’s the relative path to C:\Users\Charles
Now that I put the absolute path it works, thanks for pointing it out.
OK so this is fairly simple way to build Anduril on non Linux systems, with the exception of downloading the source code because the download link on Launchpad still doesn’t work (probably won’t ever at this point), I haven’t tried to install breezy but it looks overly complicated.
Edit : 3 builds failed : noctigon-k9.3-219, noctigon-k9.3-nofet and noctigon-k9.3, but maybe that’s unrelated.
Edit2 : yes they fail on Linux too.
Thank you very very much for your tutorial SammysHP.
This is my first time compiling Anduril, I have zero experience in this field, I played with Arduino in the past, maybe that helps a little bit.
I’m using Windows 10.
I’d like to share my experience on this project, a total noobie in this kind of thing, ran into some difficulties, so hopefully this helps other noobies who want to taste the adventure of compiling their own Anduril hex files.
I ran into some trouble (noobie’s habbit ) , basically I didn’t know what I was really doing . Many many years ago I played with VMware and Linux for a little bit. But now honestly I don’t know anything about this WSL thingy.
Then somehow I was brought here :
Manual installation steps for older versions of WSL
Followed the Steps and then my Docker is good.
This one’s the easiest part of this project
Thanks so much for your anduril-builder_v1.0_x86_64.tar.xz
This code didn’t work for me : docker load < anduril-builder_v1.0_x86_64.tar.xz
I even tried
docker load > anduril-builder_v1.0_x86_64.tar.xz
, I was thinking : “maybe the “<” was accidentally inverted or some kind of typo”
Did a little bit of Google search and found something like this :
docker load -i anduril-builder_v1.0_x86_64.tar.xz
This one works on my Windows 10.
I used Powershell btw, not CMD Prompt.
I don’t know whether it’ll work with CMD Prompt or not.
I downloaded the latest version (Revision 657) @ 2023-05-08
It’s not difficult at all.
Thank you so much ToyKeeper for this amazing Anduril
My result :
===== 59 builds succeeded, 3 failed =====
Similar to the freeman’s result I guess
Now I have a bunch of hex files in the folder “spaghetti-monster\anduril”.
But there’s no hex file for Wurkkos TS10?
This is because there’s no cfg and hwdef for TS10, right?
What should I do to create ts10.hex ?
Should I download another “Revision” that contains cfg and hwdef files for TS10? Which Revision?
Or getting individual cfg and hwdef files from somewhere else?
I think I’ve read somewhere in a BLF thread about specifying hex file for a particular flashlight in the compile process. I don’t remember the thread (nor the code).
I mean if we want to create 1 hex file for TS10, instead of 59 files for so many flashlights, how do we do that?
is there any guidance/tutorial on modifying the cfg file (and/or any other file) to get a hex file with specific characteristic ?
For example, I want to disable/delete Bike Flasher and Lightning Storm from the Strobe Modes, which file should I mod?
What line of codes should I add/subtract/alter before compiling?
Have a look at my fork, it has a lot of modified functionality as well as a compilation of build flags to use to create an image with custom settings, and a few examples.
It’s kind of out of date for the LT1S Pro, I’ve been hacking on the new multichannel firmware to try and reproduce some of my features there and hopefully might have aomethimg worth releasing there by this weekend, but it includes other recent lights like the wurkkos ts10. For more complicated changes, it’s fairly well documented and easy to mod if you know C.
Hallo,
thank you for your response,
I’ll check that…
I also read this thread
You’ve been very helpful there. I didn’t comment or asking question there, coz most of the time I don’t know what to ask. So I just read.
After being able to Reflash my TS10 and SP10 Pro to Anduril 2, somehow I’ve become motivated to learn about compiling custom hex. I read a lot of threads to learn little by little about compiling Anduril hex file.
I downloaded Atmel Studio 7 but didn’t try to install it.
I found SammysHP’s Docker method here, it works,
so I don’t have the urge to check the Atmel Studio route.
Much like when flashing using USB - TTL adapter, ZFlasher, UPDI,
mine didn’t work without resistor.
Then it works great with additional 3.3k resistor between RX and TX,
so I never tried it with Schottky diode.
