Here I took some Opple readings.
First stepped mode stock step 4
Then turbo
This led has very neutral tint for whole output range. DUV 0.0029. Beam is very pure white. It seems to sustain top of the ramp easily. If checked from XHP70.3 datasheet it corresponds to about 1000 lumens after reflector and lens losses. Not bad for 90cri led in small flashlight(led bin: 2D M2 90cri). Turbo output corresponds to little over 4000 lumens after losses.
Here’s still one photo of the lowest mode.
Next I planned to took some beamshots and maybe compare moonlight modes of different flashlights.
Quick moonlight comparison between this KR1 and Convoy M21B. Both in lowest mode and both using a boost driver of similar max output. Both also have same led.
Some piping in darkish enviroment ~20m away.
Control photo
Turbo
That’s it for now. I’m happy with this build. Only con of this light is the capacity of 18650. This driver will allow me to use every drop of it.
I suggest everyone to read TheFreeman’s driver thread. He’s closing the point of making these public. Still some UI things to solve. Anyone with skills in that regard is welcome to offer some help for him.
I will continue in near future with KR4 and 12V build.
Very nice to see the first of my HDR boost drivers assembled and used by someone other than me , Haukkeli was very motivated to go through the whole process and he provided valuable feedback, he’s a great beta tester :+1: .
In this configuration (6.4A6V) the lowest mode is ~75uA, for comparison the lowest output (li-ion) Zebralight is the SC700D at 50uA (6V), with some tweaks it can go lower but I think this is low enough.
That light looks pretty good, what driver size is that though ? it looks very small for a 26650 light.
About 22mm. I was looking at D4v2 boost driver in it. It’s very compact, though not the most compact. The machining is excellent and I have a soft spot for Jaxman. But figure if you buy Jaxman you need to plan a driver swap before you purchase.
I have one Jaxman. Their S2+ equivalent. E2 I think. I baked it, modded it to triple that uses 18500 tube but takes 18650 battery and has H17Fx driver.
It couldn’t be PWM but it could be oscillations due to instability, Haukkeli can check with the Opple though we don’t know how high it can go in frequency and since there is no noise it must be higher than audible frequency if indeed there are oscillations.
I never tested it above 6A so it’s possible the compensation values are not adequate for 6.4A. The values from the suggested schematic in the datasheet for example are only good below ~4A (at 6Vout).
I’ll assemble one with the same values as Haukkeli’s and check with the scope.
Im just asking because of Lume1 project. There was no any info of instability in nicely made data sheets, but that drivers was flickering in some cases. Stability in switching drivers is important.
I tested flicker from moonlight to turbo with Opple. I took maybe 7 samples. There was no flicker in any of them. Distortions in pictures could be from camera noise or flicker from led “fluorescent lamps”.
I continued with building 12V driver for KR4. I used stencil I ordered along with boards
On the hotplate
And flashing
I had some problems with low modes. Here I did some troubleshooting.
I ended up building another one. I also used 1uH inductor this time. TheFreeman did some efficiency tests and 1uH gained 1% more efficiency compared to 1.5uH.
Then I did some output measurements. Battery voltage was ~4.14V
Input amps
