Which single 18650 Convoy host to get?
20 posts / 0 new
SMOKEU
Last seen: 3 months 6 days ago
I already have 5x different S2+ lights and would like something that is a similar size that can take the existing 16mm MCPCB and 17mm drivers that I already have laying around. I’ll be doing either a CSLNM1 or SFT40 with smooth reflector for a mini “thrower”.
The wife also said I’m not allowed to buy any more lights this year, but a host doesn’t technically produce any light…So a host would be ideal rather than a complete light. And I have so many spare parts it would be a shame not to use them.
I’m thinking either S2, S3, S4, or S6.
raccoon city
raccoon city's picture
Last seen: 6 hours 36 min ago
Location: Palm Desert CA ~ West Coast is the best coast
Well, if you want a mini thrower, you'll probably want a deep reflector.
I don't know which of the S-series has a deep reflector other than the S2.
JenkinsMatti
Last seen: 2 weeks 2 days ago
Try a C8+ or M1 if you want an 18650 light. Both are great lights. The C8+ is a bit larger than the M1. If you want a small thrower the M1 is it. About the same size as the S2+ but with a larger head & deep reflector.
EDIT TO ADD.. You will have to check & see if the 16mm MCPCB and 17mm drivers are a fit.
I can’t remember for sure off hand
John-Atwork
Last seen: 1 week 2 days ago
Of the S series the S6 has the deepest reflector.  It would be very interesting to put a CSLNM1 into one and see what throw numbers you could get.  I'm curious how much farther it would throw than an S2+ with the same emitter.
Henk4U2
Henk4U2's picture
Last seen: 39 min 35 sec ago
John-Atwork wrote:
Of the S series the S6 has the deepest reflector.  It would be very interesting to put a CSLNM1 into one and see what throw numbers you could get.  I’m curious how much farther it would throw than an S2+ with the same emitter.
Mind you, the S6 is standard equipped with an orange peel reflector.
IDK if the S6 is also sold as a host and/or with a smooth reflector.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
John-Atwork
I didn't know that.  Maybe there is no smooth reflector for the S6, otherwise I suspect I'd find someone out there who's already stuck an osram in one.
chops728
Last seen: 1 hour 7 min ago
I’ve built several S6 with dedomed XP-G2 — made great little throwers for their time —- I use to get smooth reflectors from Fastech
If I remember correctly, there was a thread about a CSLNM1 in a S6
Lightbringer
Lightbringer's picture
Last seen: 1 hour 43 min ago
Yeh, dedomed G2s are pretty good. Dunno if anyone still has/sells white/black flats, but those are an option for a small-reflector.
Azirine
Last seen: 1 day 12 hours ago
S2, S5, S6 and S8 use the same reflector.
https://www.aliexpress.com/item/32823612116.html
John-Atwork
 >S2, S5, S6 and S8 use the same reflector. https://www.aliexpress.com/item/32823612116.html
I was going by the information in the guide I referenced above.  Maybe the early ones had a deeper reflector and then they were changed to the shallower ones so Convoy could standardize on a single needed part?
Sk9
Last seen: 2 hours 27 sec ago
M1, M2, and C8 all use 20mm mcpcb.
Sk9
The smooth s2/s6 reflector has a 5mm hole. The only gasket available is for 3535 led.
dmsoule
Last seen: 2 days 20 hours ago
I also vote for S6 with a smooth reflector. One of my first and still favorite builds is this with a warm xp-l hi. I purchased from Mtn Electronics.
https://www.mtnelectronics.com/index.php?route=product/product&path=68_1...
2puttbirdies
Last seen: 28 min 50 sec ago
M1 – it’s an awesome host
captainkirk
Last seen: 34 min 28 sec ago
I’ll second (or third, wherever we are) the M1.
The form factor to potential performance works nicely. If you want a color other than black you can always bake it before you build it…
This space for let.
John-Atwork
Azirine, chech out the fifth image.
https://www.reddit.com/r/flashlight/comments/wxk2h1/nld_convoy_s6_519a_5...
BlueSwordM
BlueSwordM's picture
Last seen: 5 hours 41 min ago
I’d recommend the Convoy M1 personally.
Sk9
Are you confusing s2 with s2+?
zaxar0580
zaxar0580's picture
Last seen: 2 hours 6 min ago
SMO reflector for S6 at Simon in Aliexpress store https://is.gd/zRyPyD
NeutralFan
NeutralFan's picture
Last seen: 1 day 3 hours ago
SMOKEU if you ever find an S4 host please let me know since it’s still on my wanted list (Want to buy a Convoy S4 – US only)!!!
I’d rather use my flashlight around the house than turn on the lights.
