Convoy S2+ 12group switch replacement
27 posts / 0 new
Lumaine Moore
Lumaine Moore's picture
Last seen: 2 days 20 hours ago
Hi,
I just bought a convoy S2+ with 519a 12group. Does this model support lighted switches? The plastic one on aliexpress says it is not compatible with 12groups. There is another metal one which does not mention this. Is any one using the 12 group S2+ with the metal lighted switch?
Thanks
Argo
Argo's picture
Last seen: 1 hour 34 min ago
Yes, I have got this flashlight.
I am waiting for the luminous rubber switch, because this metal switch is too high and the flashlight does not remain in balance, I think it should arrive in a week.
Lumaine Moore
That’s good to know. But the rubber lighted switch is not supported by 12 group version. Am I missing something?
Argo
Argo's picture
I just texted Simon to ask for this information. I quickly ordered the switches and did not carefully read the description about the limitation on biscotti firmware.
Lumaine Moore
Oh ok. Can you please kindly share what Simon says about the switch?
Thanks
Mandrake50
Last seen: 13 hours 35 min ago
I too wonder about this. I have a couple of the metal switches, but I took the one I installed out because of the tail standing problem.
I also wonder if anyone know how much current these lighted switches draw.
I have many lights. Often lights sit for long periods where I don’t use them. I just hate to need a light and have a dead battery in it due to a lighted switch.
Argo
Argo's picture
Thanks
Of course, my friend!
Wink
Argo
Argo's picture
Mandrake50 wrote:
I too wonder about this. I have a couple of the metal switches, but I took the one I installed out because of the tail standing problem. I also wonder if anyone know how much current these lighted switches draw. I have many lights. Often lights sit for long periods where I don’t use them. I just hate to need a light and have a dead battery in it due to a lighted switch.
Blue light current consumption 9.4mA, Orange light current consumption 14mA, When the battery is low and the voltage is 3.0V Blue light current consumption 2.74mA, Orange light current consumption 6.8mA,
Mandrake50
Thanks. So it is pretty significant, especially if the light may be stored for a few months. I know, I can always recharge the battery occasionally.
But so many light, so little time…
Maybe I do without the lighted switch. But I am still interested to know if there is a lighted switch that allows tail standing and work with the 12 group driver.
toddcshoe
toddcshoe's picture
Last seen: 2 hours 13 min ago
You can use the Convoy lighted switches but, you are going to need a bleeder resistor installed to rid itself of stray voltage. Without it the driver never thinks it is turned off. Half presses on the tail switch cut power then restore power to the driver, changing modes, low, med, high etc. With the lighted switch it will become a one mode light because the driver never knew the power cycled to change modes. If you need a one mode light, it will work just fine.
Turn on memory and choose your mode with the original tail switch. Install the lighted tail switch and there ya go. One mode light. Those switches do suck down the battery pretty quick. I just charge em once a month or so.
I think there is a video or explanation of how and where to install the bleeder resistor here on BLF somewhere. The search bar in the upper left hand corner should help you out.
Also, the Convoy rubber switches do not fit in the metal tail capped lights. I think only the colored ones have the metal switch. I could be wrong of course. Those metal switches used to be pressed in and were almost impossible to remove.
"Everywhere I go, there I am"
NeutralFan
NeutralFan's picture
Last seen: 1 day 22 hours ago
The Convoy S2+ with 519A,R9080,DTP copper plate,ar coated glass lens,5amps 12 groups,18650 flashlight,Torch,orange peel reflector
supports a lighted switch since it uses the
17mm Driver for SST40 ,12groups , max current output 5000mA, Temperature protection management inside
which states: “This 12 groups sst40 driver is compatible with lighted switch.”
I have many of these drivers in flashlights with lighted switches and they function as expected.
I’d rather use my flashlight around the house than turn on the lights.
Lumaine Moore
@toddcshoe
Thanks for the info, will look into bleeder resistor installation.
If only the S2+ had built-in charging, the battery drain issue would be manageable. But once a month doesn’t sound too bad.
Lumaine Moore
Can you please share the link for the lighted switches you used? Im guessing the metal ones? Also, did you install bleeder resistors for the 12group drivers?
Thanks
LTC
Last seen: 3 months 2 days ago
All those mods are the old drivers.
To my understanding, since late last year, all new 12 groups drivers support lighted switch(both rubber/metal)… I have installed them in my S2+.
Thanks
Lumaine Moore
Wow that would be great if it supports the switch out of the box. I really want the blue metal button on my gray S2+.
Thanks for the info.
Argo
Argo's picture
Mine with metal switch works perfect!
No problem.
Lumaine Moore
Can you try to loop the lanyard horizontally instead of vertically to see if the flashlight will tail stand with the metal switch?
Argo
Argo's picture
Lanyard is not a problem.
Problem is the metal switch that is higher than the tail.
The flashlight is not stable if you use metal switch and standing it on the tail.
Lumaine Moore
Damn that’s kind of disappointing Sad
Argo
Argo's picture
Thanks
Simon says that they are compatible.
Lumaine Moore
Thanks
Thanks for letting me know
raccoon city
raccoon city's picture
Last seen: 2 hours 56 min ago
Location: Palm Desert CA ~ West Coast is the best coast
We're very glad to have you here, Lumaine Moore!
Lumaine Moore
raccoon city wrote:
We’re very glad to have you here, Lumaine Moore!
Thanks man. Glad to be a part of this community.
NeutralFan
Thanks
Sorry for the late response.
I just install the regular 16mm light switch for convoy S2+ S2 C8 C8+ S21A in my flashlights. All of mine have the silicone (non-metal) switches.
No bleeder resistor is needed for the Convoy SST40 drivers.
BUT, in my experience the stock lighted switches are way too bright so I replace the resistors. I also experiment with creating different colors by mixing the LEDs.
Here’s one of my recent lighted switch mod (mix of orange and warm yellow LEDs) which resulted in a nice golden color:
Lumaine Moore
Thanks I am going to order the switches. I’ll also try to replace the resistors if the light is too bright. The color of your switch looks really nice.
Thanks
!{width:33%}https://live.staticflickr.com/65535/52328118466_f4ea559cc2_b.jpg!
Argo
Argo's picture
Thanks
I received the new switch and it work perfect. No problem Sir. It’s ok.
Lumaine Moore
That looks great!! I ordered a metal one for my S2+. Waiting for the postman.
Thanks for the updates.
Thanks
!https://images2.imgbox.com/68/cc/Rv2CuPp1_o.png!
