Do these units have the latest updated firmware version (i.e. aux LVP, aux off when main LED’s on, lower moonlight output)? And, how long does the promotion run?
Received my MAO a few days agot.Looks and feels great!
But doesn’t work properly. A a problem w/ the tail section: switch or inner tube to the switch.
I e-mailed Wurkkos but I bought it through AliExpress.
Waiting for reply.
What does it do (or not do)? What cell are you using?
yes the red color is a updated firmware
It won’t factory reset. Comes on mainly just aux and won’t turn on w’ 1 click.
When I put the MAO head on my other TS10’s I can use it normally. The MAO
switch definetly has a different feel and sound.
Tried to manipulate the inner sleeve… It sits at same height as my other TS19’s.
Battery all from Wurkkos at 3.7V
Thanks for asking
That's Great!
Good…
try this:
remove battery, tighten head, loosen, tighten, loosen, then tight again… a few times… my thought is to seat and get good contact of the inner and outer tubes, into the head
fwiw, the switch itself is a very simple affair… the issue is probably not the switch. I expect it is just poor contact from the inner tube end, to the pill.
if that tight twisting fails,
It might be poor contact at the tailcap instead.
one step at a time… the tailcap is glued shut because there is no retaining ring. If tailcap is removed, switch falls out.
btw, at 3.7v a battery is almost half empty. Youre not hurting anything by testing the light at that voltage, but I suggest you charge the batteries before any prolonged use.
Here is a photo of the tail, disassembled:
feel free to private message me if you like. I will be happy to help you figure out how to remove the tailcap, if it comes to that.
first, let us know if the twisting exercise solves the problem.
Brass arrived today and woooo baby is it beautiful!!! Wurkkos knocked it out the park with this!!
Congrats! thanks for the great photos :+1:
Beautiful! Mine should arrive Monday or Tuesday.
Looks really classy!
My brass one also arrived today (4000k with orange aux), very very nice! Some newly designed packaging with it too. Well done Wurkkos!
Jon,
Thanks for the advice. I have a blister on my middle finger now. LOL.
No change.
I’m not going to undo the tailcap. I’ll see if Wurkkos or Ali have a fix.
Thanks
Received mine (too bad I ordered it with orange aux a day before the promo)
a very very beautiful light!
94 gram copper instead of 51 gram allu version
where is copper a choice??
The brass looks awesome! And the 14500 battery is only $2 more? Must resist, must resist…
I always buy the battery with the light
I do too.
One of the TS10’s came with a 14500 with built-in usb charger !
Same length as their unprotected/regular batteries.
I thought that might have been my problem with my MAO TS10, but no.
nice option!
Both my brass ts10s say local post office, so probably monday
Wurkkos, Do you know the brass composition used in this light? The brass stock you ordered for the factory.
