Hi, the lock down in my area is over, we will start to send the exsiting orders tomorrow, thanks for your patience.
When boost driver with dual channel ?
Glad to hear you can move and operate with freedom again. Won’t it be nice someday if covid evolves into something less concerning/contagious? I remember what that used to be like. lol
Hank Wang:Hi, the lock down in my area is over, we will start to send the exsiting orders tomorrow, thanks for your patience.
With freedom? In China? You’re funny
id30209: TitaniumDust:Hank, any chance we’ll see a D4K in Cu/Ti? That would be a really good looking flashlight.
Yes!
Last email exchange with Hank I asked the same question, and...
"Yes, there will be D4K Ti+Copper version in the future."
But no ETA at the moment.
It's available
Is this the latest hex for D4S nichia? anduril.2021-12-13.emisar-d4s-219c.hex
Where to find thinner DuPont cables for the flashing holes?
hey hank, is the SWITCH RETAINING RING in the D4K Ti screw in, and only one height? From that picture I can't tell if it flat, or raised.
hey hank, is the SWITCH RETAINING RING in the D4K Ti screw in, and only one height? From that picture I can’t tell if it flat, or raised.
Hi, yes, it’s screwed in, the switch is a bit recessed in the head.
Hi Hank,
Is it possible to buy an aluminium D4K with a threaded switch retaining ring like the D4KTi has?
EMISAR D4KTI COLORFUL is here, but hank, we really need a high resolution close up for each finish.
Holy shit even the switch retaining rings are anodised!
I believe, it's not a anodisation, but fiber laser.
Colors are nice but you can’t beat brass or copper.
Re: D4KTI
Since titanium has worse thermal heat dissipation than aluminum, would it make more sense to add the boost driver here?
I bought the aluminum D4K with the boost driver add-on. Compared to the FET driver, the maximum output is lower. On the other hand, the output is better regulated. Is there any chance to increase the maximum current? I think someone mentioned 2A per LED as the default current.
D4KTI colorful version is available
Hey Hank, the D4KTI colorful D. Circuit have some markings on the copper head. It that also done by laser? Can you color the copper head too?
Does anybody know what kind of sustained output a KR1 gets with 70.3 HI? And has anybody been able to measure the duv of theirs?
Those are gorgeous, especially the crackle! Do you have higher resolution photos to share, Hank?
It depends of the colour and Cri of the 70.3 Hi LED … i measured the Lumen of my D1v2 (almost same like KR1 but with sideswitch) in the first second in Turbo as follows:
D1 | XHP70.3 Hi 70Cri | 3000k | 3230 |
D1 | XHP70.3 Hi 90Cri | 4000k | 2380 |
D1 | XHP70.3 Hi 90Cri | 5000k | 2560 |
D1 | GT FC40 | 3000k | 2080 |
D1 | SBT90.2 | 5700k | 5320 |
D1 | B35AM | 3500k | 1120 |
D1 | 519A dd | 3500k | 900 |
LG LitN
Thanks for the measurements, pretty good results
