Perhaps there's a contact issue? Maybe the Trustfire's aren't pushing tightly against the driver or tailcap springs? There have been some reports of issues with the springs getting squished shorter.
Before I modded mine, I used this light in stock form for about a month. I had no problems with any cells in this light. I am running unprotected 18650 cells from Sanyo, Pansonic, Sony. My 26650 cells are battery space LiNiCoMn, also unprotected.
Make sure the light is assembled correctly, everything from the switch pill to the driver pill is screwed down tight.
Does the problem persist with the reflector removed? If so then we can rule out a reflector short.
i prefer panasonic ncr’s or sanyo ur’s in this light.
panasonic cgr or any imr battery pulls too much current and has too little runtime in this light. 4 amps out of a solid unprotected high 2600+mah battery is fine by me. 5+ amps is pointless. at 5amps the hd2010 doesnt even seem to get hot which gets me a little worried that the drop in isnt shedding enough heat to the body.
Hi SashiX. Sorry I missed your question. Yes mine did come from DD. It was my first purchase from them and surprisingly quick delivery. I did use a coupon and got the light from memory about $32.00.
I assume though that the DD lights may have a different driver than other shops. Standard mine would draw less than 3 amps while others are getting upwards of 5 amps. DD only advertise 2.3 amps on there website, If anything can be believed on there site, this would be close.
I'm not partial to PWM so as yet I have not owned a light that bothers me particuarly with it. I cant say that I have noticed it but to others it may. I find it amusing that when doing N/O 1's in the toilet is a good way to check PWM (try it and tell me I'm not crazy). I would not suggest to check the waterproof caperbilities this way though.
Hahaha, there is no need to check it in the toilet, bro, just shake/move your hand rapidly. Fuzzy hand —> fast to non PWM driver, if you see your hand “cloned” multiple times - low PWM :bigsmile:
I’ve seen your other thread and looks like you’ve changed the driver. Can you post a pic of the old one? Maybe you get less than 3 A because of your DMM/leads
I have 3 good DMM (dont ask why I have so many) that all measure pretty much the same in voltage and current measurments. They all have heavy guage wire leads as standard. Numerous known quality batteries were tried with more or less the same current measurement at the tailcap.
This is a shot of the standard driver in my DD TangsFire.
Yup, but you need a fan for check it :bigsmile: I mean yeah, your PC has fans, but… if you have notebook? :bigsmile: And, AFAIK all of us have hands :bigsmile: Nah, just kidding
Aha. Interesting But to me, it’s the same driver UF has (East 092) Can it be because of the. lets say, “low current” batch?
Thanks
Ubehebe, as promised, I checked my Tangsfire with several 18650: Trustfire 3000, Solarforce 2400, Xtar 2600, and 2 batches of Ultrafire 3000, including one known fake. All power the HD2010 on high with no issue. I even left the UF cell in for over 5 minutes to see if it would step down. I agree with others that your issue might be something loose.
Thanks for checking batts. It’s definitely a shutdown of some kind. Nothing’s loose. Either the light is doing it (suspected) or the battery (maybe). 18650 Xtars, some flamers, all unprotected (sanyo, sony, panasonic, moli) work just dandy, but some flamers just shut off after about 10 seconds. Not the end of the world. I also have a Trustfire 5 q5 1500L that is also very picky. It’ll cycle to blinky if it gets a batt it doesn’t like. As I said, I think it has something to do with slight overcharging. Batts at 4.16-4.20 volts or so seem to trigger the shut down, or maybe there’s just not enough power in the batteries in question. I agree with whoever suggested that the 26650 would solve the prob. They’re on the way. In the meantime, I have set aside some batts that aren’t 2010 compatible. They also seem to be the ones that the 1500l doesn’t like.
Unlike the 1500L, however, it doesn’t step to a lower power, she just shuts off. If I quickly switch to a lower power, everything is fine. Looks like the flamers in question don’t have the power. Probably an AA eneloop packed in a fake trustfire flame masquerading as a real flamer…
Once again, thanks everyone. At least now I know I am the only one having this problem, which is pretty typical for me :–0
Got the copper board U2 in, does it seem any brighter? Not really to me, but I don’t have anything to measure with other than my eyes. Also the board is thinner and with the pill screwed out some it flickers and keeps changing modes, may have made it worse, not better. May send this to E1320, still debating.
copper alone is not going to increase lumen output on a cold start. Copper has the same ambient temperature as aluminum. Where it may (in theory) pay off is with higher drive currents, where it should conduct heat away more efficiently than the aluminum heatsink. But even thats debatable with an aluminum pill underneath.
Maybe you could use a thicker gasket in front of the glass to help take up the extra gap form the thinner copper?
