Not true, the stanley fatmax spotlight will top 50K. Buy how much though is debatable, as its not as straight forward as pointing the light at a meter and reading the lux.
Techjunkie has some excellent beamshots comparing OEM stock HD2010 and Stanley.
I forgot to mention that I don't like much aspherics... the FatMax is a bit big (although I wouldn't rule it out)... between the V6 & V2 which throws longer?
While at Walmart today I saw a rather interesting spotlight I may purchase since I can't find the fatmax. It is listed as 112kcd for 50 dollars. The downside is it does not have a rechargeable battery so I will be stuck running it off of an external battery.
Hard to beat a BIG-OL’ 12V incan to affordably get you north of 1500 OTF Lumens…. and a crap load of Lux too.
Double check it though, PCC showed me his Brinkman and it was a proprietary seal-beam headlamp. So you couldn’t open it up and replace the incan lamp with an H1/H2…etc. I still have a 55W Coleman incan spotlight from the mid-80s. It plugs into a cigarette lighter port.
It was only 1200 lumens. :'( Not sure whether I should get it as I already have another Incan spotlight. Of course that one is only in the 75k lux range...
I just purchased a FatMax HID. This thing is amazing and oblitrated a few of my LED throwers out the box. What mods will this Stanley HID take? I need a little direction
Maybe a Solarforce Masterpiece Pro 1? XRE is ment to be a thrower.
I have a FandyFire, a SmallSun and a Tk41. HD2010 is on the way. They all look like they have the same reflector. TK41 $120 was a thrower, then I saw FandyFire $45 could do the same for half the money, and then I found my Small Sun which could throw almost the same for ~$24 if I had a lux meter I could make a proper comparison. But I think they all share the same capabilities, with the same emitter and the same reflector sizes. Only driver currents count then, but as far as I’ve seen many times a max for a light is for a few minutes only.
All good till one with a different emitter, XML2 or such, arrives.
When I was at Lowes yesterday I was trying to decide whether I should get that for 60 dollars or the XM-L one for 30. I ended up going for the XM-L which does 110kcd by my measurements.
Scaru - I paid for $45.00 for an open box FatMax HID.I checked it out and this unit was never powered up. Im actually riding over there today , my brother loved it.
ILF - When i first read comparisons of the Stanley lights i blew them off. I really underestimated this particular FatMax HID. Once it warms up it throws a hot spot that could very likely beat some of my best throwers, Jetbeam, Ultra-fire, even Surefire... Ouch...ok, that hurt. Its true..Lights don't lie.. Quality is so-so. Cant compete with some of the high grade anodizing and its not built to last. The performance on the other hand sorta makes up for the crap build. If you want to review it i'll throw it in the mail? ( i"ll place gently) Shoot me a PM if your interested
[quote=ILIKEFLASHLIGHTS]
That is awesome! How do you like the quality on the Fat MaX?
[/quote]
The Jacob A60 is one of the best throwers for the money. Can be had for under $20. I’ve tested them at 500M and about 57Kcd. Not much spill but a great thrower. It just edges out the HD2010 which costs roughly $30. I’ve measured them at about 450m and about 49Kcd. It offers a lot more spill than the A60 though. For under $50 dollar throwers, those two are hard to beat.
Im pretty sure you’ll have the same impressions of the Fatmax. If you get it PM
i want to know what you think. Once it warms up its pretty amazing…Who knows how to mod
this or upgrade the HID bulb? 2100 or Kriesler should know this…
