Thanx nightcrawl, your previous commnent is valuable for me (although I dont understand it 100, maybe 90 but thats wenough I think )
Ill buy than XTAR or HiMaxes, depending of the price, and Ill buy CGR or IMR if I maybe get some newer version of lavatube without 2,5A limit
If you are buying Trustfire 300mAh, you need to check that they have the 5A pcb, Trustfire make them with three different pcbs.
It also sees to be the same cell as the 2400mAh, both tested at jaround 2600mAh 1A. The Trustfireb 3000mAh get really hot hen a high current is drawn. Check the comparison below, surface battery temperature constant 15W power, 5A max.
Panasonic CGR18650CH – 35.8 deg C
Samsung INR 18650-15Q – 34.6 deg C
Sanyo UR18650W2 – 31.7 deg C
Panasonic NCR18650A – 33.7 deg C
Trustfire 3000mAh 2C – 48.1 deg C
AW IMR 2000mAh – 34.9 deg C
AW IMR 1600mAh – 28.9 deg C
I included the Trustfire to see how a standard Li-Ion chemistry would compare, and the Panasonic NCR18550A to see how effective their Heat Reducing Layer is – pretty effective I would say.
Those Samsung look a good price, but they need to be charged to 4.35v and drained to 2.5v to achieve 3000mAh, Realistically they are about 2800mAh.
Who knows, maybe Ill get one or 2 samsung (but I dont need a dozen of them :o ), I can charge them to 4,35 at my hobby charger, but who knows…
I wonder what is their discharge curve…
I wont give any money for 3000 TF flames because its too much of a gamble (only if I’ll get warranted capacity and PCB quality from some website, if someone from few good webstores confirms me wich cell I will get - but I dont want to bother with that too much.).
I found reliable supllier for TF 2400 and Im buying these for some flashlights (I mean, its a gamble with 2400 also, and 3000 are higher priced and its also a gamble, and I dont want to take it at that price, and to find reliable supplier for some good TF3000, if thats possible at all now, need time and effort etc. SO for these better quality protected Ill go with XTAR or HiMAX. For lower but still reliable quality and capacity there are these good TF2400. And for even lower quality but very good price-value ratio I’ve found Ultrafire 2400 protected - real capacity around 2000 - from DD 5,99 a pair, wiuth coupons etc 5,0$ If I get what I ordered :o) And they even have less voltage sag than most TF flames)
I dont know, those from link in first post (but thats to big quantity, I need two pcs max of those. When I posted them, I didnt knew that they had to be charged to 4,35 for full capacity. And they are also not protected so not suitable for most of my applications).
The Trustfire 3000mAh and 2400mAh I just tested were almost identical apart from the pcb - the 2400 cut off at under 4A.
Hopefully they will be on the blog at the weekend.
PS: BTWm, if you wont best bang (mAh_) for a buck, Ultrafire protected 2400mAh are far superior to anything Thay have cca 2000mAh per 2,5-3 bucks from dinodirect (if they really send you these cells, I ordered a coupls so Ill see - I say to you, they are better than most TF flames 2400mAh out there, only PCB is little weaker, cant stand 3A)
@torchy, too many diagrams, I browsed through cca 20 of them and than I quit :o
Good quality Ultrafire are few and far between. You end up wasting a lot of money trying to find decent quality. I know, I’ve done it. That’s why I started the blog, to save others from wasting their money.
Yesterday I r/eceived 12 HiMax 2600mAh from pingyi ebay seller.
They look great and I was thrilled to have them.
But now I started discharge test and Im quite dissapointed.
I have iMax B6 hobby charger from Dinodirect. I put 1A discharge to 2,8V (from 4,15V).
In 20 seconds voltage droped to 3,62, and in 1 minute it dropped to 3,59. (same as trustfie flames, but some very bad ultrafire can have little better voltage sag).
Now 5 mins past and its 3,51 (6 mins and its still 3,51V; 11mins its 3,45V)
So results are totally inconsistent with diagram I found on this website.
FInished discharging - first cycle - 2293 up to 2,80V
Thanx HKJ (btw, can you out time on ghorizontal axis maybe?)
(Illpost comparison diagram later I dont have time now)
But thats precisely source of my doubting.
Himax cell Im testing right now gives resultrs as trustfire flames 2400mAh cell, not Himax - especially regarding voltage drop…
Maybe some other cell from the package will perform better, but if they are oscillating so much from cell to cell - thats not acceptable…
Im not prone to pay more just for the label or just few mAh higher capacity
I will post the full review later today, this includes also charts with a time axis and all HI-MAX curves in the same chart (Like all my other battery reviews).
