Lights Flickering
5 posts / 0 new
sonofbuster
Last seen: 2 months 4 days ago
Lights Flickering
i have two 14500 lights -- a C3 and S10 -- and both (especially the C3) have an intermittent flickering issue. it's a high-speed flicker and shaking or tapping the light usually fixes it. i think something may be loose inside, but i have no clue as to the inner workings of these things. any ideas or suggestions?
scruffy dog
Last seen: 6 years 7 months ago
make sure all contacts are clean and it is all screwed together properly   try tightening the switch i have had a few lights with similar faults and it is usually somthing not tightened properly
Andi
Andi's picture
Last seen: 10 months 3 weeks ago
Sometimes it´s the contact between the clicky and the spring to battery -.
I had this problem on Eastward YJ J08.
The spring is soldered separately and contact is only 100%, if this 2 parts pressed togehter.
If tailcap was screwed out (only a little, little bit) contact can be interrupted.
Don
Don's picture
The C3 is primarily dependent upon the body biting into two solder blobs on the head - they can give trouble.
See here
http://budgetlightforum.cz.cc/node/250
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Boaz
Boaz's picture
Last seen: 7 hours 38 min ago
Tail first .. I have a small victorionox knife with small sicissors on my key chain and i use them spread out to hit each hole and crank the tail cap tighter .in my experiance that is 85% of it right there... if it's loose at all  then it's the cure .. the heads more of a pain  one  thing is the reflector mashing / over mashing the emitter .. some lights want it to happen some lights no,as it short out the emitter , solder blobs of course as was stated by don ..  try the tail first  try jumping around the tail with a paperclip or a wire to make sure .. to isolate the problem ...OR  Buy 20 more  lights ...  < most widly used  method on BLF
