Dunno…haven’t built it yet
I’m thinking something along the lines of a P-60 drop-in. An XM-L with a floody lens would be ideal, since it would really test the “integrating” of the sphere.
How do you know the exact lumen output though, this is the problem i’ve been thinking about, there are no markings on an xml saying which bin it is (we have to trust what we buy is correct), and even in the same bin there is a minimum luminous flux.
That’s a very generous offer - I would very much like that, thanks !!!
I have not mounted the baffle nor made the final cuts, as I don’t have the dedicated meter in-hand. I made an off-axis circumferential cut in relation to the valve hole to allow for 90-degree placement of the two openings, and resealed it with a single layer of masking tape prior to putting on the first coats of paint. It will take but a small pass with an exacto to rend the sphere in twain for baffling and barium sulfate coating.
It’s the same stuff that you ingest in the chalky milkshakes (or enemas) to provide contrast in G.I. tract radiology scans.
It is also used to provide a fantastic diffusion coating for integrating spheres, minimizing any favoritism of throwers over floody torches.
I think you may be a bit confused. What I intend on doing is piecing together a drop-in (spec's aren't that important), and then testing it in my I.S. and obtaining the numbers for it that way, then passing it along. It's a rather crude way to calibrate I.S.'s, but really the only practical way... It will also ensure that my future lumen numbers match ChicagoX's and anyone else who would like to use the calibration drop-in.
I used a light with known consistent output, my sc60, to calibrate mine. After that I tested against others like my Ti to confirm it is consistent and accurate. I don’t know about a home made drop in with so many variables. Sounds sketchy to me. I know mine is accurate. If you don’t already have an ANSI rated light, borrow one from someone nearby or buy one.
I think the drop-in is a good idea. I think I am pretty accurate with the lights i have to test but it would be a good comparison. Another reference point. Sphere is looking good X.
JohnnyMac, Langcjl hopefully makes my point a little more clearer. If there's a bunch of us with I.S.'s, it would be nice to have one light or drop-in to use as a reference that we can pass around. As far as a homemade drop-in with so many variables, as long as it's current regulated it won't matter in the slightest. The drop-in lumen rating won't be calculated off of any data sheet, but rather in my I.S. then passed on.
I thought my explanation to Bort was clear on this intent...but hopefully this helped a little more.
Would you have to qualify which light the drop in was used in, such as a single 18650 light, versus a 3AA light, or a 26650 light? Or which exact batteries were used? I hear “regulated”, but I’m still wondering what would happen if a battery that was marginal in amperage or voltage wouldn’t mess up the test?
Ya, but you know me... Have to do it differently. Like making the first layer of newspaper out of "gores", so the inside has very neat seams. Using the weldwood for stiffness and longevity. Using some type of fabric like denim or strong cotton, for more stiffness, etc, etc, etc. LOL, it's got to be a challenge and it's got to be a one of a kind. I just don't know any different.
Almost all the light for white LEDs of any color temp is between 425 and 750 nm. There is a pretty significant peak at 450 nm and virtually nothing below 425 nm.
So when you shine the light inside the sphere, do you shine it straight at the baffle? I'm assuming so given the point of it is to stop light going stright from the torch to the sensor.
No, you shine at the opposite wall. The baffle actually means an imperfection in the sphere geometry and thus is something bad, but direct light from source to detector is much worse.
What about making the first layers out of white paper?
I want such a sphere too and I thought that if we all get our olight i6s(I guess a lot of us have ordered this light) we can calibrate our spheres to each other…
