On the official Ultrafire shop page looking at the UF-H6.
Looks like the unit that E1320 has with the addition of the solar panel and case.
If I had any faith that the solar panel worked, I would be out $29.00……
I contacted the shop, and they stated that the case was wired and that the unit would charge inside of the case, but I can’t see anything like that in the picture.
I don’t have any apple devices but my girls smart phone needs one amp and it works for that. It’s also worth noting the flashlight head has a USB port and makes a great nightlight.
The flashlight is pretty nifty, and the beam would be awesome if it wasn’t puke green. I just like wide floody TIR beams. If they made P60 dropins with TIR beams cheap, I’d be all over them.
If you want to get all fancy with gadgets, and you your kinda lazy when it comes to recharging.
A 5 or 10kmah cell and all the adapters you can possibly need and gone for the weekend
Seriously, with a good pack you can easily go all weekend with an I-pad, 2 cell phones, and charge a bunch of 18650’s.
is the seller I used, and the picture looks like it’s the same from the front panel. That said, I can’t vouch for the fact that anything would be the same as I bought mine almost a year ago.
Mine does have a tp4056 inside, but for all I know, it could be decorative. Maybe I’ll try a charge cycle and see what the termination voltage is. I don’t really have the setup to see what kind of current it’s charging with.
Edit: just charged up and it looks (to my cheap dmm) like 4.19 volts after a bit of a rest. Not bad.
For the issue with some boxes, not charging i think some fones need a signal from the usb cable. Maybe i’m wrong but there was something about a resistor on the usb connections in the charger signaling what charge current the fone should take.
I have pretty much at least a couple of all those 18650 5v usb chargers mentioned. Atm using OP’s version as my edc and it will sometimes just stop charging my phone for no apparent reason. This one is more ‘automatic’ in a sense as it can detect when i unplug my phone and switch off. Charging via mini usb seems to work ok. Just wish their was something with more than one battery bay that is reliable. Will take a look at the hobby king suggestion
Does the ML-102 fit the blf favorite 18680 xtar? (edit: actually 68.5mm, but who's counting?) I have a few repurposed ipod chargers (cellboost irecharge IPR3) that just happen to have USB-in, USB-out, and takes 18700 with some soldering, not worth the hassle to do it again. Would have gotten the ml-102 if i'd known about it earlier.
How efficient would that setup be? Say a 10000mah 7.4v lipoly with that adaptor? How many watt hours are we talking compared to 4x18650 on one of those ebay boxes (70-80% efficiency). Video at the link you provided looks pretty convincing. cheers
I’d prefer the charger that wouldn’t need assembling (putting a battery in) whenever device needs charging. but since ML-102 has so many positive feedback I’ve ordered one and I’m waiting to receive it.
I just received a 1s4p charger with an adjustable output current today (check out #170880896962) and I’ve been charging individual cells up in it while powered from my ML-102 (don’t ask why, lol). So far so good, the 1s4p charger has been terminating early at around 4.083V.
Will do a couple discharge tests from it to see if it will do low voltage cutoff correctly, if this doesn’t die in a month’s time like another BLFer’s experience from such charger boxes, I’ll be a happy camper
I have the 'same' pack and found that my batteries died very quickly while sitting and waiting to be used.
I put in 4 freshly charged Flames and let it sit for almost 3 weeks.
When I tried to turn it on I didnt get any of the lights on even after pushing that button inside. I tested the batteries and found a low voltage (it was a couple months ago now).
Just wondering if you'd seen the same thing?
If I put fresh cells in and don't press the button would it last longer?
