One question, can you tell me if there will be any battery fitment issues, whether using 18650 or 26650 as there was with the Roche F12 and F8? If I purchased it, I’d likely be using a Trustfire TR 26650 5000 mAh or a Redilast 18650 3100 mAh. Thanks.
The description says tail switch, but it sure looks like a side clicky.
Do you click the side switch once to turn it on and then press and hold to ramp the brightness up then down?
Hey, that last picture on the site (see link in the OP) looks like it has an extension tube for 2 x 26650 or maybe even 3 x “C” cell would fit? Does it come with the extra tube, Ric? Ahhhh, I just saw…$5 extra for the extension tube. I measured some batteries and I bet it would work with 3 x “C” cells.
I really need to stop visiting this damn site! I would be all over this, but I’d like to see the guts. I would love to mod this like I did the UF-T50.
EDIT: Duh, I should probably click the link and look at all of the pictures. This looks like a modder’s dream! Threaded in side switch and driver, I’m going to have to order this!
It comes with Side switch. It’s our typo. Only Upgrade JM07 has 2 switchs now.
UI is like this:
1. Press side button, turn on the light.
2. Hold the button till the light flicker once, the mode goes to Stepless brightness. Press and hold the button; Current will step down from 3000mA to 50mAh.
When it goes to low brightness, Hold the button till the light flicker once,Press and hold the button; Current and brightness will rise up from 50mA to 3000mAh.
3. Click the button twice when the torch is on, UI goes to 3-mode(hidden). Strobe>Alarming flash>SOS
Hi Cainn, I’m sure it must be an option. IOS is selling them too and actually shows the bezel as an option. I think I’d opt for the non-crenelated bezel myself.
Hi Ric,
Does It has memory mode?
I mean when I set brightness to 50% and then take out battery, That brightness will be 50% or anything?
I don’t like Ultrafie UF-T50, It has no memory mode. When I take out battery . It will start at High mode.
Thanks.
