MattSPL
(MattSPL)
August 14, 2012, 12:03pm
162
Here’s my current draw results for the Mini-01
Trustfire primary - Low 0.08A, High 0.8A
Surefire primary - Low 0.06A, High 0.75A
Ultracell 3.2v LifeP04 - Low 0.1A, High 1A
AW 3.2v LifeP04 - Low 0.13A, High 1.09A
Yezl 3.7v 16340 - Low 0.25A, High 2.4A
This explains the brightness and hand burning heat when using the Yezl cell :bigsmile:
Edit: I have just tested the Mini-01’s current draw on 2 different 18650 cells.
Senybor 3100mAh(Panasonic) protected - Low 0.27A, High 2.55A
Panasonic GCR18650CH - Low 0.30A, High 2.9A
JustFit
(JustFit)
August 8, 2012, 11:39am
163
MattSPL:
Thank you Matt for the readings… it seems that I have a faulty one.
hmmm…
Anyone else has a mini-01 that draws only 1 Amps in High mode on 16340 ?
MattSPL
(MattSPL)
August 8, 2012, 11:43am
164
Is it possible that the Trustfire flame isn’t capable of delivering any more current, rather than the light being faulty, because your readings are very similar to mine, except for the Yezl cell?
JustFit
(JustFit)
August 8, 2012, 11:47am
165
MattSPL:
yeah, but don’t forget that trustfire flame is 4.2 fully charged , and I’ve also tested the mini-01 with Hi-Max 18650 cells which deliver a good 5 Amps on my Trustfire TR-J12 …
MattSPL
(MattSPL)
August 8, 2012, 11:58am
166
Yeah not sure to be honest. Have you any other cells to try?
Suncoaster
(Suncoaster)
August 8, 2012, 12:30pm
167
I get
.08 and .85 on the original Trustfire CR123A
.11 and .98 on SOshine RCR-123 protected.
But my cheap DMM leads read low compared with better wire…
I need to make up some better leads.
MattSPL
(MattSPL)
August 8, 2012, 12:46pm
168
Thanks for testing your Mini-01.
Hopefully some other people can test theirs too.
alex21
(alex21)
August 8, 2012, 2:17pm
169
Thanks man. Unfortunately the only camera I got is the one on my phone… tried last night but it came out too crappy
alex21
(alex21)
August 8, 2012, 2:23pm
170
MattSPL:
Nice… got to get me some of that hand burning goodness for these winter nights
mags
(mags)
August 8, 2012, 2:34pm
171
Glad I picked up the Yetzl cells…
MattSPL
(MattSPL)
August 8, 2012, 2:36pm
172
Now i just need to get hold of an AW IMR 16340. That should be really fun :bigsmile:
alex21
(alex21)
August 8, 2012, 3:25pm
173
Good one. Should be interesting J)
mags
(mags)
August 8, 2012, 9:57pm
174
Is the AW IMR better than the Yetzl? By how much?
MattSPL
(MattSPL)
August 8, 2012, 10:10pm
175
I don’t know enough about flashlights and batteries to give a definite answer, but this is what i think: I bought the Yezl 16340 because it has the highest tested capacity ive seen, and it is rated to handle upto 3.2A discharge, which, from what i can tell, is very good for a 16340 cell.
The AW IMR 16340 is capable of 4.4A max discharge, but will also have a much lower internal resistance due to design and lack of any protection circuit. This means it will perform better in a light that needs high current delivery, especially a direct drive light like the Mini-01 seems to be.
So in theory, the AW IMR 16340 should make the Mini-01 even brighter. You would just have to take care not to let the IMR discharge below 2.5v(as it has no protection circuit), or it will shorten cell life.
Cheers
Matt
mags
(mags)
August 9, 2012, 1:23am
176
MattSPL:
Cheers
Matt
Thanks Matt
http://www.oveready.com/batteries-chargers/aw-imr-16340-rechargeable-battery/prod_113.html
JohnnyMac
(JohnnyMac)
August 9, 2012, 1:21am
177
As soon as mine arrives I will post figures using my TF flames as well as OTF lumens in my IS.
Tecmo
(Tecmo)
August 9, 2012, 1:27am
178
Flames work fine in mine. They’re from DX.
MattSPL
(MattSPL)
August 9, 2012, 12:43pm
180
Yes, the Trustfire flames 880mAh seem to be a good 16340 also. Torchythebatteryboy tested them as having 658mAh capacity at 1A discharge.
feilox
(feilox)
August 12, 2012, 2:18am
181
So I heard it last 6-8 minutes on high. How much do i get with these AW & Yezl cells?
