I have that soldering station and love it to death it’s awesome and I have used quite a few high end units.
When I bought mine last year people were reporting the wires were improperly routed and the units would burn up.
It’s very important that you open up the panel on that soldering station and make sure the wires are properly routed.
These Hakko tips from KD fit perfect and are very reasonably priced. Only order one or two because they randomly ship the big cutting tips for some reason. http://kaidomain.com/product/details.S003297
Nice to see the low is fairly low and medium useful for a battery saving high.
[/quote]
I’m doing a run off between the S-Mini (high 360lm)& the e1320 5 mode on mode 4 (about 350lm) using the same kind of batt (cgr18650) fully charged. neck & neck @ 45 minute at this point. The winner shall receive a gold medal. LOL BTW, they are holding at 113 f (45c) so no heat issues.
Hard plastic battery case bought to hold the growing collection of batteries I have recently and relentlessly accumulated in the past few weeks. Trustfire X100 +batteries/charger which I just had to have. This is by far my most expensive purchase but since I really needed some 26650 cells it made allot of sense.
This also finally came in from way back when it was talked about on here. Great light and it came with both the 4aa and 26650-18650 adapter.
Hifi can be budget, can be non-budget Slowly working my way through to the budget beaters of the audiophile end.
The white ones are LSK M4 - budget kit speakers for a balanced performance from a small budget ($99 each, $200 a pair at the time) Not too bad at all, but low and high extensions are rolled off to say the least, but present in a very tonally balanced and are easy to listen to.
Bamboo built one stained dark cherry is the Ascend Acoustics Sierra-1, Extremely clear with huge soundstage, and very good low end extension (very good candidate for a 2.0 setup). Slight midbass depression IMO, but reviewers described it as midbass transparency… but other than that an AWESOME set of speakers. cost me 25% more becasue if shipping to australia, but still worth it.
And the sub was just received (still in plastic wrap), Rythmik F12SE, servo sub, with the feedback control to improve accuracy and speed. Regardless, a small 12” cube with better extension (and quantity) than an existing 12” isobaric box thats twice as big! Its the quality of the bass is phenomenal, and the onboard parametric equaliser is what sets it apart from most plate amp subs.
ATC loudspeakers look very very fancy!
Sorry for the off-topic nature of this post, I shall bring it back slightly with a new light source in my room! With integrated blue led glow becasue neon isnt cool enough, however I prefer the warm tint at night though…. (oh and that LED light was an old headlamp that I made, now re-used as a under-bed light, now illuminating the driver so I can see the cone movements through the grille. Brightness adjustable from dimmer than tritium to some 200 or so lumens, enough to get hot)
Nice setup. I knew i’d seen that sub somewhere before, the drive unit look familiar. I’ve heard great things about the Rhythmik gear.
I had a pair of ATC scm19’s, then scm50asl’s, and now some more industrial PA-65’s.
Sorry for going off topic also.
Here’s a funny light/electrical tester. Its a Fluke LVD1
Here’s a beamshot of mine. Check out the beautiful beam
I received it today. Throw is actually not too bad. Lens is very curvy (more than my other XML zoomies), so, if my imaginations i scorrect, less light escapes the lens when totally focused.
I have one brick church tower 360m from my house, and it can lit it very dimly. Average C8 Q5 throws further, but of course beam is much tighter. Its interesting light, and it seems that it isnt very mildly driven like some zoomies.
PS: I think it would be really interesting to mod it with XPG R5, I cant wait to do it (I bought 2 of these just for that purpose, to mod one with r5) Even with R2, if you want very good thrower and dont mide weak spill. This lens is very interesting, its glass as I can see and very curved). It looks 2 times more curved than lens of SMall Sun C10, maybe more than 2 times!!
