3x AAA alkaline (fresh out of the packge) = 4,8V, but the internal resistance of those batteries is higher than the resistance of a 18650 lithium-ion cell. So the current could be a little higher on a 4,2V 18650 cell, but i don't think that will destroy the led.
If there was a lithium-ion cell with a diameter of 21-22mm and 52mm length, it would fit in the battery tube. A protected 21500 schould be perfect to replace the 3 AAA cells (with the protection circuit it will be a bit longer than 50mm).
At least in theory. Many people have driven XR-E's at up to 1400mA though it will not last as long at that current. Heatsinking is imperative for you to be able to drive them hard.
It's just a hollow aluminium pill with very thin edges, and the empty circuit board and led star constitute its bases (air between them).
I don't think I should drive the LED at any more than 700mA (which should be plenty bright for my needs - with the current 300-400 mA it draws now it is bright enough).
I just wanted to use the 18650 to gain more run time, not more brightness (but that's a bonus, obviously).
It ought to be possible to bodge a resistor in somewhere that it can be removed when required. Or turn it into a twisty and use some quantum tunnelling material between a couple of bits of metal as a switch. The stuff is cheap.
I doubt even good AAAs can sustain 2A for any length of time, even the worst 18650 shouldn't even break sweat. If the light is designed to limit current depending on the internal resistance of the cells, lowering the resistance of the cells will inevitably raise current. All cells sag under load - alkaline AAAs sag hard - 18650s sag a lot less - so you have at least as many volts and more amps.
I'll try this with a Solarforce L2i which can use both.
With a Solarforce 0.9-4.2V single mode dropin.
Three LSD AAAs, 4.264V output on lightbox and current
That's what is coming out of the cells. Emitter draw is harder to measure and requires soldering before and afterwards. 1600mA is almost certainly losing a fair bit as heat. 4.2V is well past the Vf of the LED so I suspect the driver is dumping quite a bit of that as heat. You'd need to ask one of the guys round here who knows about electronics about that - my knowledge could be printed out and comfortably inserted into my eye.
The OP light says the emitter is a Cree P4 so around 1000mA Cree spec but you should get away with 1200mA in short bursts without cooking the LED. 1400 if you have really good heat sinking.
So if I take the resistor approach - I guess we're talking about at least 2W resistor? Preferably 3W I guess.
If I know the internal resistance of the battery / battery pack - can I calculate the current I'll get through the resistor? If so, I may be able to pick a resistor such that it will work well with both battery configurations.
Couldn't find a suitable driver, though I searched qutie a bit. Seems that drivers whose max output is below 1A are taking only 1.5V input, but maybe I missed something.
Got some great news for you Haggai I received the extension ring and like yours it doesnt fit... BUT I was so frustrated to fit an 18650 into c30 that I figured it out! 18650 fits C30 without extension ring! You just have to remove the tailcap spring and unscrew the ring that holds the switch. Now you have almost 1 cm more space and 18650 fits without a problem! Just try it! And to make things even better (at least for me ) the extension ring fits onto another 3xAAA light that I got.
I really love my C30 now - its really small for a 18650 light - a whole 1 cm smaller than already quite small Trustfire TR-801 + its a zoomable light. Now if I could only somehow fit a QTC pill in it and it would be a perfect light for me. The led did turn a little blue (from 6 months on 14500 DD), but with QTC and improved heat transfer (thermal grease) I dont think it would be a problem anymore. Size comparison:
I was wondering where you guys got the extention ring and after hearing it doesn't fit ....ah .. never mind ...:~
I like my c30 if that is even what it really is ?? ..I have no idea what emitter is even in it but it's pretty warm and it's a 3 mode ..I still think it's a great light partially because of the tint ..maybe also because it was my first real led light
