I have the Yezl and AW IMR 16340’s.
The Yezl look and feel like a good quality cell. The wrapper is nice, it all has a solid feel to it. The AW has a plain red wrapper that is very thin and cracks easily. I have had to tape both my 2 day old AW cells.
I measured the Yezl supplying 2.4A to the Mini-01, and the AW IMR measured a peak of 3.07A and a steady 2.8A.
The IMR is definitely brighter, but doesn’t have a protection circuit for over discharge, but if you are careful, you can tell when it’s time to recharge. Using mine on and off for a minute or so a few times in a row is enough to discharge the cell to the point where it’s no longer fully charged and it’s not supplying the full amount of current anymore. You notice a gradual dimming of the light, and if you turn it on when the cell is half full, you will notice it doesn’t get too hot to hold either.
The light does go through a cell quickly, but I have been quickly removing and testing the cell voltage when it’s clearly visible the light has gotten a bit dimmer, and I’ve measured 3.6-3.7 volts, so provided you keep an eye on it, there shouldn’t be much chance of over discharge.
The light was pulling 1.68A from the Yezl at 3.7v, so that explains the visibly dimmer light.
For brightest output, the AW IMR 16340 wins(not by a huge amount, but it is brighter), but it won’t last quite as long as the Yezl, and doesn’t have a protection circuit.
Mods can go in many directions, but that would defeat this little lights purpose I think.
The only mod I think would do great in this light is a smooth reflector to improve throw.
That was quick :bigsmile:
What type of cells have you tried in the Mini so far?
I got the IMR’s from Flashaholics in the UK. They were the closest place to me that had them in stock.
If you google AW IMR 16340, you should come across plently of Vaping sites selling them that might be nearer to you.
My keys got snagged in my pocket, and when I yanked them out my mini01 fell on the floor. It came off the keyring holder at the attachment point. Maybe a fluke, but watch out for it.
Did it hit the floor hard? I hope it survived anyway?
The Mini-01 has a bit of weight to it when it has a cell in it. The supplied key ring is too weak imo.
I swapped mine when it arrived and put a lanyard on it. I don’t carry it on my keys, it just sits in the pocket and can be easily found and pulled out with the lanyard.
Ok, that’s not too bad then. The mag key ring will hopefully last better.
As for charge current for the Yezl cells, i’m not sure to be honest. I would think they are like most other 16340 cells. I saw mention of 16340 charge current in a HKJ review where he described 600mA current being just within range for a 16340, and the IMR 16340’s can be charged with upto 1.5A.
so far, ive only tried the white trustfire cells that came with it, some blue ultrafire cells, and the extream beam cells.
i will google aw imr but i just didnt wanna buy from a seller that sells fake ones. so i was just seeing if someone can recommend me a good seller.
not sure if this has been posted, but i found a way to get momentary for the mini.
just turn on the mini, and back turn it off ever so lightly…just a 1/8 turn or so.
now when you press the tail cap, it should have a momentary switch. i found this to be a neat lil feature now. so if i needed light just for a quick second, instead of having to twist to turn on, i can push the tail cap in.
