The custom modes will be ready by then? Ok, will do. :D
Scaru you are a lucky guy!
Yeah, I can't wait to get it. :D My first BLF branded light. I may get DHL shipping so I get it sooner.
zeremefico:Scaru you are a lucky guy!
I just realized this is in the thread about the X6, where you talking about the X6 or the Mini 01?
scaru: zeremefico:Scaru you are a lucky guy!
i meant X6, and u meant?
scaru: scaru: zeremefico:Scaru you are a lucky guy!
I was talking about the Mini 01. Would it be possible to get it done on that?
WWEFANS: scaru: scaru: zeremefico:Scaru you are a lucky guy!
can do the blf.com.
but sorry, for custom mode,L/M/H, needs 100pcs.
or it costs really high for only one.
and i'm pretty sure factory is not willing to do this.
really sorry.
scaru: WWEFANS: scaru: scaru: zeremefico:Scaru you are a lucky guy!
can do the blf.com.
really sorry.
Don't worry about it. Would it be possible to get a stock Mini 01 that says BLF on it?
WWEFANS: scaru: WWEFANS: scaru: scaru: zeremefico:Scaru you are a lucky guy!
can do the blf.com.
really sorry.
will answer you on Monday after checking with them. stainless is different with aluminum.
ok,have to take shower and go to bed,
you guys have a nice day,
scaru: WWEFANS: scaru: WWEFANS: scaru: scaru: zeremefico:Scaru you are a lucky guy!
can do the blf.com.
really sorry.
Ok, thanks for doing this for me. :D
scaru. How do you get boxes in boxes?
You mean quote multiple posts with in each other? You just press the quote button in the bottom right corner of the post.
MRsDNF:scaru. How do you get boxes in boxes?
See. :D
scaru: MRsDNF:scaru. How do you get boxes in boxes?
See. :D
Ok. Thats all good, but I have seen it with different posts in the one reply. Apologies for taking this of topic.
scaru: scaru: MRsDNF:scaru. How do you get boxes in boxes?
See. :D
Like this?
If so, just first click quote and then open in new tab of one of the posts you want to quote and then do the same for the other. You then take the text in one of the messages and cut and paste it into another.
WWEFANS:hi guys, just found this thread.
X6 Modded to 11.4A
here is link to buy the driver.
I currently have that light and as E1320 pointed out the thermal protection kicks in to quickly. I am going to do a test today to see whether it is my batteries or the driver.
In the laser world, most folks would want to thermal paste some small pieces of copper heatsink to some of the ICs….even copper coins would do.
Why don’t you guys search for that power resistor mod to the original driver? Fast and pretty easy, and it works. You can have 9-10A to the SST-90.
The problem is not the driver, it is the heatsinking. As I said in the other thread the it went down to low when the LED reached 200 degrees. This is already to hot.
It looks good to me….
LEDs don’t really go way down in output due to heat…yes there is some effect to the output but not exactly visible by the eyes.
I mean i have gunned triple XM-Ls at like 6A constant in the Sky Ray 3800 for about 30s. That is 18 amps bro, no joke and i was using 12V SLAs constantly charged to maintain the voltage (which affects current).
My TF X100 is about the size of the TF X6, same weight and same head mass etc. That’s about 3.6A at the tail. Granted it is way more efficient @ 3300L OTF, but heat wise shouldn’t be so far off. I could gun it for 20 mins, easy.
Wanna re-apply the thermal compound? There seems to be no anodisation in the thermal path to the external fins and 6061 mass to impede.
scaru:The problem is not the driver, it is the heatsinking. As I said in the other thread the it went down to low when the LED reached 200 degrees. This is already to hot.
It looks good to me… LEDs don’t really go way down in output due to heat…yes there is some effect to the output but not exactly visible by the eyes. I mean i have gunned triple XM-Ls at like 6A constant in the Sky Ray 3800 for about 30s. That is 18 amps bro, no joke and i was using 12V SLAs constantly charged to maintain the voltage (which affects current). My TF X100 is about the size of the TF X6, same weight and same head mass etc. That’s about 3.6A at the tail. Granted it is way more efficient @ 3300L OTF, but heat wise shouldn’t be so far off. I could gun it for 20 mins, easy.
Keep in mind it took about 2 minutes to get to 200 and was still rising. Yet the fins were just barely warm. With out the thermal throttling I could probably cook on the flashlight.
Then there is something wrong somewhere. I have been playing with hot stuff like my SR3800 with DRY turbo driver and my 4 X DRYs with ice and dry ice and drivers till i got sick of the inefficiency. LOL! The heat should get out to the fins pretty fast, even though it is just aluminum. The same goes to the higher powered lasers as well……them diodes are much more sensitive to heat.
