Sanyo AA XXeloops
+1000 :bigsmile:
OCD - Obsessive-Compulsive Disorder Surprised
Wtg for the discharge results which will give a more accurate result for their capacity but its looking good. Wish I had spent extra and just got the xx instead of the standard eneloops. I have 12 coming and I dont think I really need them.
I just got done with the 100ma discharge and these numbers look a lot more normal too me.
100ma discharge:
1. 2480 mah -- ICV = 1.48v
2. 2489 mah -- ICV = 1.47v
3. 2495 mah -- ICV = 1.47v
4. 2485 mah -- ICV = 1.47v
5. 2483 mah -- ICV = 1.46v
6. 2441 mah -- ICV = 1.47v
7. 2465 mah -- ICV = 1.47v
8. 2462 mah -- ICV = 1.45v
ICV = Impedance Check Voltage
So now I just started the break-in which should take about 40 hours or so. I'll post these numbers as soon as it's done. Stay tuned folks.
Dang....those cells are looking pretty good. I'd pick some up, but I still don't even have a decent charger.
Thanks for the work in testing you're doing, Fishinfool!
Anytime Match. It's the one and only thing I can contribute to BLF since I hardly know anything about flashlight electronics. Maybe someday it will all sink in. I guess I'm just a veeeeery slow learner.Frown
Im glad to see your batch works as good as they look. Will they receive the beer christening while at sea... like the outboard engine? Surprised
It never did cross my mind but any reason to go out fishing is a good reason. We just have to wait for some decent weather.
WHERE can I get that?!
It's a discount store here in the U.S. Closeout items, etc.
Any chance to get international shipping with that price? :/
[quote=ezeqdb]
[/quote]
I've sent out a few packs of these to members here. Shipping is kind of a killer. It's @ $16 to the U.K. and I want to say it was ~$6 to Canada. I have no idea what it would be to Argentina. But yea, we're kind of lucky to have biglots here. I just picked up another charger/4pack plus another 8pack because they're working out so well.
source
xx batteries are sexxy looking. (Now I know I have a problem!)
I must stop spending money in this stuff!
Interesting discharge graphs, but which current draws are those lines showing? <- do you understand my spanglish?
Finally, after 40 hours or so (I've acually been testing these 8 cells since 2-23-11 which is 4 days of testing---man I need a lifeFrown), the final break-in numbers are here and they are right where I'm used to seeing sanyo eneloop numbers at.
Break-In @ 2500mah:
1. 2476 mah -- 1.43v
2. 2444 mah -- 1.42v
3. 2439 mah -- 1.42v
4. 2454 mah -- 1.43v
5. 2456 mah -- 1.42v
6. 2450 mah -- 1.43v
7. 2467 mah -- 1.43v
8. 2448 mah -- 1.42v
Now all I have left is to do all of these tests I've been doing to the last 4 XXeloops (cells 9-12) and then I'm done.......for now anyway.:bigsmile:
It would be interesting to see some run tiime tests to see how much longer the xx last over regular eneloops
You should make a runtime-test and bright measurement with one flashlight, first using normal Eneloops and then XX Eneloops. To compare if there is an increase in brightness (may be they have less internal resistance).
Very nice test, and very nice batteries. I just hope not to be drunk next to the computer or I will do the same
@ ezeqdb - When I'm done with the last 4 cells I'll try doing some kind of runtime test. I've never done one so I might need some advice as how to make the test fair and equal between the original eneloops (or 2nd gen eneloops=the colored ones) and these new xxeloops. Smile
Here's some numbers on cells 9 - 12:
500ma discharge out of the package:
9. 1323 mah -- ICV = 1.43v
10. 1319 mah -- ICV = 1.43v
11. 1316 mah -- ICV = 1.43v
12. 1320 mah -- ICV = 1.43v
ICV = Impedance Check Voltage (after 500ma discharge)
Don't feel so bad - I have 64 AAs and 16 AAAs - and I give them all a break-in every twelve months, and keep a spreadsheet with records going back to when the cells were first purchased. (Feb '07 for the first 28)
Anyway - quick question - what are the voltages you've got listed next to your break-in results?
Cheers
It's the C9000's final voltage after the final charge at the end of the break-in mode but it actually drops down to about 1.35v after an hour or two.
