Many lights have a screw-in PILL or tailswitch, where the part is screwed in via two depressions machined into the metal. Is there a special tool available to install and remove those parts or some household tool that isn't coming to my mind right now? A small screwdriver works well sometimes, but the ideal tool would sit in both depressions at once, to get better leverage and help guide the part when inserting, and it would have an adjustable width between the depressions.
Needlenose pliers?
+1......I filed down a cheap tool to ~2mm/side
I use stainless steel tweezers found pretty much in all HK shops for 1usd or so.
Thanks for all of the ideas. Needle nose pliers work well for my lights that aren't too thin or deep. I may also try some blunt tweezers like one of these, though I'm a bit worried they won't be able to tighten as well as the pliers:
http://www.dealextreme.com/p/weitus-stainless-steel-precision-straight-tweezers-19870
http://www.dealextreme.com/p/weitu-antistatic-replaceable-straight-tweezers-19920
http://www.dealextreme.com/p/hozan-anti-static-esd-professional-tweezers-8498
If that doesn't work, I may try and make my own out the the clips.
Circlip pliers are ideal, but they're expensive. I use needle nose pliers.
very easy/cheap solution:
take 2 long (~8cm) nails, or screws.
insert both in holes an screw....it works really good.
after they cross over, you can screw, for more "power" = more crisscrossing.
This one is perfect and not expensive , small, short and strong, however at least here are hard to find..
You can get very cheap ones - which are essentially consumables when used in automotive applications but are just fine for torch use. I got mine for about $6 from DX.
http://www.dealextreme.com/p/snap-ring-pliers-4-piece-set-8484
You can probably get them in just about any shop that sells tools for not a lot.
Another good alternative is a watch opening tool - they are usually under $5
Put "round nose pliers" into eBay and you'll get a million economic options. The trend for making your own jewelry has really helped on the price of these as they are used for making loops in wire for ear rings and the like.
Cheap pointy nose tweezers less than a buck and really suck at being tweezers ..Or I use the tips of small micro schears meant for snipping small electronics off of boards ..I have a few realy nice sharp wonderful pairs of exlite brand snips and some older ones that are impossible to sharpen correctly so they get abused even more .. you only ned them to break them loose after that a tiny screw driver eyc ..
