Hi there! I received my hd2010 today from tmart. Package was slighly damaged and lamp had scratches but that didnāt bother me after three week waiting. I installed 26650 battery and wtf?? The threads of tail cap were really tight but installed tail anyway. Now I canāt get the tail cap offā¦ Other thing is that only high and strobo modes are working. So now I must contact tmart and propably send the light back and wait another 3 weeks or what is their way of handling issues like this?
edit: first time I inserted battery the threads were tight, then tried 18650 battery and all modes were working, after that the jam happened when I put the 26650 battery back. Now the battery is stuck also in the lampā¦ I wonder do I have to broke the lamp to get my battery off or do I have to send the whole package to tmartā¦
the same thing happened to me just the other day. i thought i was screwed too. i was able to get it loose though by spraying wd 40. see if that works for youā¦
My HD201 from Tmart sequence goes like this: Press fully to turn ON, always starts on High, half press to cycle through, Med - Low - Strobe - SOS. With flashlight turned ON, half press for at least 3 seconds on ANY mode and it will return back to high.
Andi, what method did you use to dedome it? I dedomed my ZY-T13 using the ārun it till hot and peel off the dome with your fingernailā technique but the lux didnāt change. I still only get 39k out of it. Horrible!!
I use a razor blade and cut in the dome a little bit on the opposite side of the bonding wires. Then use tweezer, hold star and press the dome directly on a cookplate(full power) for 25sec.
Then lift the dome with fingernail at the cut.
Iv got a U2 led & a 4amp (intl outdoor) driver firstly will the 4a be overdriven with the U2 & secondly whatās the easiest way to sandwich the smaller driver in? This will be my first proper Mod iv only just replaced my small sun C10 driver to a 105c successfully yesterday has some good THROW now! Cheers in advance for any help!
Its the same driver I've had here for a couple of weeks but have not had time to use it yet. I have modified my stock pill slightly and have a driver in it at the moment so cant tell definitely if it will fit, but a quick measurement and eyeball I reckon it will squeeze in ok without any mods.
I have that same driver in my cart right now, with a few other bits and pieces. Havenāt pulled the trigger yet though. It seems like the perfect driver to use when you want to over-drive an XM-L, but within reason.
