Hiya Folks,
This is going to be a brief look at two models, spefically the RC-G2 and the RC-29. The Dickensesque post title is slightly misleading, because even though I'm going to cover 2 models, I have 4 lights total. I'm going to be comparing one of each as delivered from dealextreme to their counterparts from shiningbeam.com. I'm sure most of you have seen the "upgraded" models sold on that site for ~$6-8 more. So, what does that extra money net? Let's take a look:
Well, this is embarrassing. I was just looking up the links to the above lights from dealextreme and SB, and I realized I have no idea where my original RC-29 came from. Hell, I think I ordered it awhile ago from SB as well...Doh! Well, at least the data makes more sense now. So, I shall sheepishly continue.
The candidates:
Romisen RC-G2 from Dealextreme $11.99
Feautres a Cree XR-E LED Emitter
- Glass lens with aluminum reflector
- Powered by 1 x AA battery (1.2/1.5V)
- Single mode tailcap clicky on/off
- LED bin code: XRCWHT-L1-WG-P2-0-01
Romisen RC-G2 II R5 from shiningbeam $19.75
* 200% brighter than the regular RC-G2 Cree P3/P4 model with the older driver
* 48% brighter than the latest RC-G2 stock model
* Customized aluminum reflector to take advantage of the XP-G emitter
* This new model comes with latest driver and Cree XP-G R5 1B tint LED
* LED type: Premium Cree XP-G R5 1B tint
* Up to 150 lumens output
* Orange peel aluminum alloy reflector
* Tactical momentary-on forward switch
* Glass Lens
Romisen RC-29 II R2 from ? (SB I think....crud, this is bad..) Here's the token link to the one from DX $15.10
* I know it's got an R2
* hell, it looks brighter than the stock model (which until now I thought I had...)
* The lens has been custimized by my car keys in my pocket for about 3 months
* No clue on the driver...but it gets sad if fed anything more than 1.5v
* Tactical momentary-on forward switch - Confirmend!
* Plastic lens much like any other flood to throw....
Romisen RC-29 II R5 $21.75
* This is the customized version of the RC-29, which uses a brighter Cree XP-G R5 LED, 1B tint
* Using the latest driver and it is 45% brighter than the regular model
* Water resistant design
* Aluminum alloy casing
* Using a convex lens which enable the output beam from flood to throw
* Compatible 1x AA Alkaline or 1 x AA NIMH
* ShiningBeam.com is the only store carries this model of light
Ok...so now we've established basic facts like specs, price, and my goldfish like memory. Let's briskly move onto the more interesting details. All testing done on fresh alkalines, because odds are that's all these will ever be fed. I did try the SB RC-G2 on both eneloops (2.2a meh) and NiZn (3.7a whoa):
Model | Tailcap Current | Lux@1m | Ceiling bounce |
DX RC-G2 | 2.4a | 4.0k | 3.7 |
SB RC-G2 | 2.6a | 3.1k | 5.1 |
? RC-29 | 2.0a | 550/4.6k | 3.6 |
SB RC-29 | 2.5a | 490/3.1k | 3.2 |
I double checked the results because it looked like there were a few anomolies, such as the current and output of the R2 RC-29, but the data was the same every time. So, let's conclude with a few observations:
- The SB RC-G2 with the upgraded driver and XPG put out a lot more light, at the cost of a litle throw as compared to the standard DX affair, and looks like it's worth the extra coin.
- The standard dx rc-g2 throws about as well as the SB RC-29 in throw mode.
- There doesn't seem to be any compelling reason to get the xpg version of the rc-29.
- I've confirmed I'm not fond of twist to throw.
- I really need to keep better track of where I get stuff...
Thanks for your time,
-Match
