A couple questions about lights and p60 drop ins
1c3man,
I was in the same boat you were in about 4 months ago....Up until then, the brightest torch I owned was a 15yr old streamlight and I couldn't tell a pill from a pie-hole. So, here's some advice, and what I did:
Start going through some of the old threads, especially if it's one with a technical discussion and just read them (there's quite a few posts and pictures going over drop-ins and drivers here). Granted, you may not understand much of the jargon BUT at least you'll be exposed to it. As with any new subject or hobby, be it particle physics or popsicles, answering your particular questions without a good baseline reference won't get you far.
Think of the information like puzzle pieces. It's hard to put the puzzle together without a picture, but it's even harder to do when you haven't even seen all the pieces yet.
Yea, I know...my analogy stinks, but hey it's waaay past my bedtime.
If that sounds like too much work, then here's the short answer based off of your original question:
Buy this for your L2.
http://budgetlightforum.cz.cc/node/505
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI4M3JYMUVwM0E&hl=en&authkey=CIOSsoMI#gid=1
http://www.dealextreme.com/forums/Forums.dx/Forum.-209~threadid.530221
http://www.forolinternas.com/viewtopic.php?f=22&t=996&p=10295#p10294 you might need bing/or google translator or learn spanish
http://www.candlepowerforums.com/vb/showthread.php?188772-pictorial-review-of-LEDs/page2
http://en.wikipedia.org/wiki/Inverse-square_law
http://img85.imageshack.us/f/flux.jpg/ . >> arrows right and left to toggle between pages
http://fonarevka.ru/ blows my mind everytime I go here i spend hours.. I hope I'm getting a virus or lossing my credit card info because it's totally worth it .Amazing fun data base .. play with stuff on the right and on bottom right ..flasoholics dream
http://www.cree.com/products/pdf/XLamp7090XR-E_B&L.pdf
http://www.gearcarrot.com/guides/lights/?p=toc
http://flashlight-wiki.com/
Listed in order of output at maximum power, least bright to most bright:
Luxeon Rebel 040-bin (84+ lm @ 1A, ~3.5W)
Luxeon Rebel 050-bin (105+ lm @ 1A, ~3.5W)
Luxeon Rebel 060-bin (126+ lm @ 1A, ~3.5W)
SSC P4 S1-bin (127-141 lm @ 1A, ~3.5W)
SSC P4 S2-bin (141-165 lm @ 1A, ~3.5W)
Luxeon Rebel 070-bin (147+ lm @ 1A, ~3.5W)
SSC P4 T1-bin (165-188 lm @ 1A, ~3.5W)
Luxeon Rebel 080-bin (168+ lm @ 1A, ~3.5W)
Cree XRE/XPE P4-bin (177-192 lm @ 1A, ~3.5W)
SSC P4 T2-bin (188-214 lm @ 1A, ~3.5W)
Luxeon Rebel 090-bin (189+ lm @ 1A, ~3.5W)
Cree XRE/XPE Q2-bin (192-207 lm @ 1A, ~3.5W)
Cree XRE/XPE Q3-bin (207-220 lm @ 1A, ~3.5W)
Luxeon Rebel 100-bin (210+ lm @ 1A, ~3.5W)
SSC P4 U1-bin (214-235 lm @ 1A, ~3.5W)
Cree XRE/XPE Q4-bin (220-233 lm @ 1A, ~3.5W)
Luxeon Rebel ES (225+ lm @ 1A, ~3.5W)
Luxeon Rebel 110-bin (231+ lm @ 1A, ~3.5W)*
Cree XRE/XPE Q5-bin (233-251 lm @ 1A, ~3.5W)
SSC P4 U2-bin (235-256 lm @ 1A, ~3.5W)
Cree XRE/XPE R2-bin (251-268 lm @ 1A, ~3.5W)
SSC P4 U3-bin (256-280 lm @ 1A, ~3.5W)*
Cree XRE/XPE R3-bin (268-286 lm @ 1A, ~3.5W)
Cree XRE/XPE R4-bin (286-306 lm @ 1A, ~3.5W)*
Cree XPG R2-bin (380-406 lm @ 1.5A, ~5W)
Cree XPG R3-bin (406-433 lm @ 1.5A, ~5W)
Cree XPG R4-bin (433-463 lm @ 1.5A, ~5W)
SSC P7 A-bin (440-570 lm @ 2.8A, ~10W)
Cree XPG R5-bin (463-493 lm @ 1.5A, ~5W)
Cree MCE H-bin (490-560 lm @ 2.8A, ~10W)
Cree XPG S2-bin (493-520 lm @ 1.5A, ~5W)
Cree XPG S3-bin (520-547 lm @ 1.5A, ~5W)*
Cree MCE J-bin (560-648 lm @ 2.8A, ~10W)
SSC P7 B-bin (570-700 lm @ 2.8A, ~10W)
Luminus SST-50 F-bin (635-823 lm @ 5A, ~18W)
Cree MCE K-bin (648-753 lm @ 2.8A, ~10W)
SSC P7 C-bin (700-800 lm @ 2.8A, ~10W)
Cree MCE M-bin (753-858 lm @ 2.8A, ~10W)
SSC P7 D-bin (800-900 lm @ 2.8A, ~10W)
Luminus SST-50 G-bin (823-999 lm @ 5A, ~18W)
Cree XM-L T5-Bin (845-910 lm @ 3.0A, ~10W)
Cree MCE N-bin (858-962 lm @ 2.8A, ~10W)
SSC P7 E-bin (900-1100 lm @ 2.8A, ~10W)*
Cree XM-L T6-Bin (910-975 lm @ 3.0A, ~10W)
Cree MCE P-bin (962-1085 lm @ 2.8A, ~10W)*
Cree XM-L U2-Bin (975-1040 lm @ 3.0A, ~10W)*
Luminus SST-50 H-bin (999-1175 lm @ 5A, ~18W)
Cree XM-L U3-Bin (1040-1105 lm @ 3.0A, ~10W)*
Luminus SST-50 J-bin (1175-1410 lm @ 5A, ~18W)
Luminus SST-50 K-bin (1410-1645 lm @ 5A, ~18W)*
Luminus SST-90 K-bin (1410-1645 lm @ 9A, ~34W)
Luminus SST-90 L-bin (1645-1998 lm @ 9A, ~34W)
Luminus SST-90 M-bin (1998-2350 lm @ 9A, ~34W)
Luminus SST-90 N-bin (2350-2820 lm @ 9A, ~34W)
Luminus SST-90 P-bin (2820-3408 lm @ 9A, ~34W)*
Red = <60 lpw min.
Orange = 60-75 lpw min.
Green = 75-90 lpw min.
Blue = >90 lpw min.
*(not yet available)
[EDIT: colorized according to approx. lpw]
if you know that .. you'll be wise like don ... there is a test in 3 weeks
I certainly don't know all that - I just know where to find it when I need to.
Thanks for posting this list. It helps big time. I'm going to print it out and keep it handy.
"And in swoops Boaz to take all the fun out of the Easter Egg hunt..."
1C3Man, Boaz just hooked you up. That's a lot of excellent information to go over, and now it's all in one neat spot.
Nice work!
WOW. thats the stuff i was hoping to find thanks alot.
It's a gift.....
some got it .. some don't
I don't. Frown
That's because you keep gifting it away :P
LOL
lpw min = uh, lumens per watt, minimum? So blue are the most efficient/longest running (in terms of battery life)?
Here's a noob with a (probably) already asked/answered question:
How many amps do you suppose my stock L2P or L2 is pulling with the 3-mode Ultra Fire XM-L from Manafont with a Solarforce 2400 mAh 18650? Are they seriously at or near 900 lumens? I was thinking they were closer to a real world 400 to 600 range.
veryusefullistboazFoy
[Pedantic stuff alert]
Apologies for the attack of pedantry about to emerge.
The yellow stuff is the phosphor which is actually coated on the die which emits blue light. The phosphor turns the blue light into a range of frequencies leading to us seeing white light.
The junction is the bit that emits the blue light. Since the phosphor coating is about ten nanometres from the die, this is an ultra-pedantic point. In practice what you see is the yellow bit which is the bit which gets hot.
But that's enough pedantry for one day.
[/Pedantic stuff alert]
Actually, I reckon this is an excellent summary.
Thank you.
Foy
Now that I didn't know!
So that mean that blue LEDs are cooler at a given current? (or would be if they were availlable at the same spec as white ones)
As far as I'm aware, all white LEDs are phosphor coated blue LEDs - there are inevitably some losses in the wavelength changes, though what I meant (and said rather badly - in fact wrongly) was that the yellow-coated bit is the bit that gets hot. Most of the heat will be from the LED, not the phosphor. Craig over at FNF has a spectroscope and has done measurements on all sorts of LEDs.
http://flashlightnews.net/forum/index.php?topic=798
The spectrum of just about every white LED will show more blue than would be optimal. Sixty545 here has done interesting colour measurements on current LEDs.
The parent blue LEDs (those under the phosphor of white LEDs) will be brighter, but not far off monochromatic and blue light is not a good match for human eyes. Blue light makes everyone around you look ill. AFAIK nobody sells non-phosphor high power LEDs in their native blue. But it wouldn't be the first time I've been wrong....
Ahh thanks for the info Don :)
I will borrow this topic, as I don't want to start another one with same title than 1000 others. And it's still on-topic, as I have a couple of questions about lights and P60 drop-ins.
Unlike the starter of this topic, I'm in a search for very bright floodlight with good runtime. I have Solarforce L2X extended tube coming in and I want to get a dropin that would give me huge wall of light and keep it going for couple of hours on 2X18650. I really only need one level, but 3-level is fine also. What are my options? I see that most XM-L or P7 dropins are 4.2v max, so no-go there. Any high voltage XM-L, SST-50 or P7 out there? I'm willing to pay decent amount for the dropin, but not Malkoff prices. Let's say up to 50$ would be ok.
Custom driver:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=7947
With self improved heatsinking if the host of choice requires it (all p60 would) and you should be fine:
Host perhaps:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=11103
Change driver only if the stock sux.
KD have 1 mode XM-L U2 drop ins http://www.kaidomain.com/ProductDetails.aspx?ProductId=11249
