26650 Batteries
It probably has a 18650 inside it (laptop salvaged as well)
Hi guys, new to this flashlight world. I’ve been reading many threads on here and this forum has been very helfpful.
I was wondering if anyone has had any experience with the SoShine 26650 4200mAh protected Li-ion batteries, I found them on tmart for $8.99 (and has anyone had any experience with tmart.com?). Here’s the link to them:
http://www.tmart.com/1-Pcs-SoShine-26650-4200mAh-37V42V-Protective-Liion-Rechargeable-Battery-with-Board-Black_p161839.html
i picked up a trustfire 26650 from tmart today - i am interested to see if it performs as good as the mf battery… i already noticed that tmarts length and weight of the battery is slightly different (tmart length 2mm shorter and slightly lighter than mf)
i have a 26650 king kong to compare to when it gets here (i do not have a hobby charger)
:bigsmile:
Now; no longer have a 26650 :bigsmile: :bigsmile:
Some day some one will make better 26650’s.
not going to wait around me at 71 ain’t got not time to waste |(
Hello, dial and welcome to BLF. Have not seen any information on Soshine cells, but at least their capacity claims are within reason. Tested protected TrustFire 5000mAh are available for just a few more dollars from several sources listed in the OP (Though they are more like 42-4400 mAh actual capacity). I have used TMart for several flashlight purchases and had good experience, but I have not made any battery purchases, nor will I until I see some of their cells tested. If you do try these, by all means let us know what you think.
Welcome to the party, dial!
KD has 6000mAh 26650 cells. I’m curious what is the real capacity and chemistry
http://www.kaidomain.com/product/details.S020635
I have one "Trustfire PCB 5000mAh" 26650 cell from T-mart, when I bought the HD2010 I had no 26650 at all and thought why not buy all together.
Bad choice.
The HD2010 is perfect, don't get me wrong, the only problem is that the 26650 cell I received is NOT an original Trustfire.
First of all, it's NOT protected. It says on label about pcb being green blah blah, but reality is that there is NO pcb at all! (that explains also why the Tmart spec are 2mm shorter than other Trustfire 26650)
Second, the wrapper is very badly shrinked on, I can make less wrinkles when I do my own RC packs heating the shrinkwrap with the phon!
Capacity is still unknown, as I've not had time to perform a real capacity test with the RC charger (being unknown cells, I have to arrange things to make the test outdoor, as a safe precaution). Anyway, I used it on the HD2010, checked voltage and ampere consumption, and sure they don't lack in punch, as I recorded a steady 3,4A barely touching the cell bottom with the prongs, without pressing the spring, and quickly increasing over 4A if I pressed the spring, so did not wanted to push the luck further.
Still I use it on the HD2010, being a single cell light I feel confident that when I avoid any overdischarge there's no real risk.
But I switch to KK INR 26650 if I have to use the HD2010 for long periods.
So the final consideration is: BE WARNED, the 26650 T-mart sells under the Trustfire 5000mAh wrap are fake and not protected.
It's theoretically possible, but I seriously doubt this is legit. Anyone with a hobby charger and a gambling spirit want to give it a shot?
Thanks for the info Rockspider. If these were listed as "US Warehouse" I might have jumped on them before reading this! Wonder what Louis and Sherry Ye here on BLF would have to say about this.
-Garry
Just checked the link. It's now listed as 4500mAh. I still wouldn't buy it. Too many better options out there from trusted resellers.
-Garry
I PM'd Sherry about this. Will let you know any reply.
Sherry asked from some pics of the aforementioned cells to see what the problem is, so I thought that I could share those pics with you too.
First the original Trustfire 26650 PCB 5000mAh that HKJ has tested on this thread: https://budgetlightforum.com/t/-/8149
and this is the one I received from Tmart:
Note the shape and gap around the +button, the difference in the yellow flame shape, the colour of the +TF26650 3,7 Li-ion- lettering above, silver on his and grey on mine.
Then note that the cell is shorter, both on top and bottom it misses the black portion present on the original ones, where the PCB disc and +contacts are.
The original cell measures 68,3 to 68,8 (depending on batch, apparently) meanwhile mine measures only 66,7. Missing the PCB, obviously. Weight is also lighter, 89g versus 92-94g for the originals.
Now the +button, on left the original protected, on right the Tmart one.
Bottom of cell, again on left HKJ tested original cell with PCB, and on right my cell without. The difference is pretty visible!
Next is comparison between labels, note that mine has a badly printed label with fuzzy fonts and colour overlappings between yellow letters and red flames.
original PCB
fake unprotected
detail:
Detail of bottom, clearly showing that there is no PCB
The cell charges and can be used, but without PCB protection and without knowing what kind of chemical the cell is (ICR, INR, ...) I would not feel safe to use it for prolonged periods.
Wonder if I should consider safe to use it in the HD2010. Being unknown brand 26650 cell, is it a safe assumption that being a 26650 sized, it can safely supply 3,4A to the driver without grenading?
generally speaking, there are few safe assumptions
and there are even fewer when dealing with an obviously counterfeit cell…
Thanks for updating us Rockspider. I'm interested to see how T-mart responds.
-Garry
Hi all,
I've had a long PM exchange with Sherry of T-Mart. She has been very nice and helpful, that's something to note when dealing with customer service.
Initially she said they did not know anything of those cells, and asked for more detailled infos and pics.
After that they agreed that those cells do not have a PCB and agreed that their website add must be changed accordingly (see now it says without PCB), even if only in the last line of the description:
http://www.tmart.com/1Pcs-TrustFire-26650-5000mAh-3642V-Lithium-Battery-Black-and-Red_p150233.html
Those cells are supplied to them from an external supplier, and the only info they got from him is that those unprotected cells are Lithium-Cobalt chemistry.
They offered me refund for it, but as the unknown-brand cell is anyway working properly, and also considering that sending it back the postage exceeds the cell value, we settled on a partial 50% refund, which seems to me fair enough.
I will soon test this cell with an RC charger to monitor real charge/discharge values, just for curiosity.
Sherry also pointed out that they have another add which has cells with PCB, but goes for sale two cells together:
http://www.tmart.com/2pcs-TrustFire-26650-5000mAH-3642V-PCB-Protector-Rechargeable-Lithium-Battieries-Black_p150234.html
Personally I would have liked the website add changed with clear explanations that those cells are indeed clone cells, like CNQG does on some cells with indication "genuine" and "copy", but this is up to the store owner. Now the "without PCB" is there, anyone reading will make his own considerations.
How about leaving product feedback on this on the product page so others can read about it there too?
-Garry
I want to have real capacity numbers to judge the value of this cell first.
Thank you Rockspider
Thanks for the update, Rockspider - very valuable information! I am getting to the point of giving up on most China suppliers of cells outside of CNQG, IOS, HKE and yes Manafont. The first three always seem to stand behind what they sell (In my experience) and Manafont always seems to have good cells, or at least they test better than most. Even when they sell counterfeits, they label them as a Mimic. Dino, DX and TMart have all been caught and called out multiple times for selling fake batteries - I won't purchase from them in the future. eBay? Forget about it.
In light of this post about wrappers from dchomak, I think we should all exercise more caution in who we buy from.
