Here is the reflector from the Keygos KE-303 compared to a C8. Too bad there are other problems with the light.
This reflector throws a nice tight beam with an XM-L, but the pill needs work
Always nice to see a good review of a <$20 light!
Thanks for another great review. I bought a C8 U2 from Lightmalls after reading your review, and agree with your comments. It is excellent quality, and as bright as my 5 x R5 light. I’m waiting to get my TR-J16 and will post some comparison beamshots.
And I’ve just placed an order for this C12 from Lightmalls - You should get some commission from them !
Yeah I should get commission, but the thing is, I do these reviews for the fun of it. Just to let the world know what I think is good. If I get commission, it just gets too serious and makes it seem like a chore to do.
No, I was just joking. Anything to do with commissions will mean the questioning of the bias in the reviews. And as it is, there is enough twisting of the truth elsewhere in Web-review-land !
Really, its thanks to people like yourself and all the other members here that we can come here and find out for sure if a products is really good or it sucks.
Thanks for a review and good pics!
I ordered 2 myself to see, how these compare to my former C8’s
C12 right - C8 left
so, which one is brighter, Lightmall C8 U2 or C12?
The C12 is driven a bit better, and it seems brighter too. Yeah it is pretty strange, maybe it is because the colour tint of the C8 is NW and the tint of the C12 is slightly cooler.
Chriszhou, I need your suggestion, should I buy c12 or kaidomain c8?
Personally, I don’t really know, since I do not own a KD C8. Both are very good lights. The C12 might be a little better driven, and it does have better heatsinking.
But since I am unbiased, I cannot say for sure.
You can never know until you have both
I love your reviews, Chris. So how does the C12 compare to the C8 in terms of grip and feeling in the hand?
And what about the lux? If this will upstage the U2 C8 in brightness, how is the throw?
Replying to the Rusty Joe’s last two comments, I personally think that the C8 feels slightly nicer to hold in your hand, as the C12’s heatsink fins reduce the grippy area of the flashlight. You may find that with the C12, your hand might jut out past the end of the tailcap, which is definitely not that comfortable. That being said, the two flashlight’s body tubes are almost identical, so the knurling on both is nice and not too protruding. For some reason, the C8 also feels slightly heavier, but the actually weigh the same.
Since the reflector is the same on both the flashlights, and the U2 binned XM-L has the same dome as the T6, it might be fair the say that the C12 has better throw, only because it is driven a bit higher and can maintain the same amps to lumens efficiency for longer.
I do not currently own a lux-o-meter or whatever they are called, and do not intend of getting one any time soon, so I can’t tell you the exact lux value.
I just got my C12 in the mail today. It is also very well built, confirming what Chris has found. Nice to know there is some consistency in the manufacturing !
I did a comparison with the C8 (both are from Lightmalls as per Chris’ reviews) and the C12 is noticeably brighter than the C8. I’d estimate between 5 and 10% brighter to the naked eye. (My DMM is playing up, so I can’t provide any measurements) I thought maybe it was the battery (using Trustfire 2400s), but swapping them around gave the same result.
Go figure - supposedly the C12 has the T6 and the C8 has the U2 - not sure what this means ??!
Thanks very much! Frontpage’d and Sticky’d.
Sorry, I forgot to update:
Both arrived in good condition. Quality was IMO better than in “generic eBay C8” flashlights.
DD random C8 was also in general worse.
These both were functioning good, taking both over 3A when measured from tailcap.
I remember getting a bit mixed values from some C8 ´s.
I think I can recommend these, will order some more shortly and post back how they end up!
Received two more today.
They are in good shape, both pulling around 2.5 - 2.8Amps.
The other has white background around emitter die, the other one has black. Others emitter is a bit off from center but otherwise they are fine.
Hi - newbie here!!! Nice review chriszhou… I ordered this based on your write up. I placed my order from lightmalls on February 10 and guess what - Chinese New Year Holiday in effect from Feb. 5 - 18. So still waiting.
But I went ahead and ordered Orbrtonic’s 18650 Smart Li-ion Charger and Two 3100mAh Panasonic Lithium-Ion Rechargeable Batteries Kit for ~$45. Are these the right batteries for this particular light? (Yes, I am that new to flashlights!)
Thanks all. looking forward to a new addiction!
I haven’t ordered a C8 or C12 from LightMalls yet but based on my experience with my C8 from AuraBuy, protected 18650s work fine without any problem. I’m using Protected Sanyo UR18650 rated at 2600 mAh.
I hope this helps.
