TrustFire TR-800
7 posts / 0 new
FlexakaMal
Last seen: 11 years 1 month ago
TrustFire TR-800
Can they run on 1 x 18650 ? just wondered because it looks like they have an extension .
Don
Don's picture
Last seen: 1 year 1 month ago
If it is the same as everything else using that body - Ultrafire WF-500, Romisen RC-T6, Romisen RC-T5 then no. The extension is CR123 sized. It allows for dangerous things like running 1RCR123 and an 18650 but is intended to let you use 3 or 4 RCR123s.
I think.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
FlexakaMal
I think.
I will let you know I guess. I have a body on order for a project involving a MC-E Laughing
Mcgrath
Mcgrath's picture
Last seen: 8 years 9 months ago
I dont know if anyone is still interrested in this topic, but is is exactly as Don said, the extension is as long as a 16430, see pictures.
moniac
Last seen: 9 years 7 months ago
TR-1200(short body, same TR-800 body) works with single 18650 with spacer or with 3x16340 or 1x18650 and 1x16340 witout spacers. If you plan to use 3x16340 check the maximum voltage of the led driver. TR-1200 perfectly works with 3x16340.
Don
Don's picture
Welcome moniac, good to have you here.
fishinfool
fishinfool's picture
Last seen: 2 years 4 months ago
Aloha and welcome to BLF moniac!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
