Rockspider
(Rockspider)
October 4, 2012, 10:57am
89
Received yesterday the new EDC with XP-G2 emitter.
Was very curious to see this new emitter and have to admit it's impressive for its size.
At 1,4A is not nearly driven to its full capability, but nonetheless the output is great and the colour is a very natural pure white, I like it!
In this very small application, with a small reflector, it gives a very wide hotspot, definitely biased to flood for short distance usage.
Now I want to see XP-G2 on larger reflectored flashlight, tuned for throw!!
digitaltim
(digitaltim)
October 12, 2012, 12:11am
90
Can anyone recommend a holster for this light?
I’ve looked quite a bit, but none seem to be a close fit.
gords1001
(gords1001)
October 12, 2012, 6:43am
91
Mine turned up yesterday. Very nice, and very impressed with the kit packaging, going to try and get it built up tonight. 8)
Tom_E
(Tom E)
October 12, 2012, 11:47am
92
I'm using this: http://www.manafont.com/product_info.php/terminator-yrg-industries-nylon-holster-for-flashlight-p-7113
It does ok, little tight as the reviewers say because the material is so strong, but the light fits fine.
NickBose
(NickBose)
October 13, 2012, 6:56am
93
Any BLF discount on this light?
rojos
(rojos)
October 17, 2012, 5:29am
94
BIGWOOD:
Dissasembled.
I can't tell from the photo. Is there Fujik or some other thermal compound between the star and the pill?
BIGWOOD
(BIGWOOD)
October 17, 2012, 3:52pm
95
Yes there is thermal paste under the star.
I just switched the driver to a KD v2, 3.05A driver. Low - Med - High with memory. I'm using the 2.5A driver that came with it to power another light. It was very easy and quick 10min job. I'm not sure if my eyes are playing tricks on me but it looks considerably brighter. Might be that it was dark outside...
M3TAL_L0RD
(M3TAL_L0RD)
October 18, 2012, 2:50pm
97
It will fit but light won't work with it, tailcap doesn't make contact with clip
You can modify tailcap little bit to make it work. Adding spacer to where body's end should make contact.
EDIT:Piece of paper clip did the job... not nicest fix but works.
And picture with SolarForce clip.
flame2000
(flame2000)
October 27, 2012, 10:13am
98
Hi guys,
Anyone knows what’s the estimated OTF lumens for Low mode (5%) for this light with the 1.4A driver board on a XP-G2 R5 LED?
TIA!
scaru
(scaru)
October 27, 2012, 1:15pm
99
It should draw around 70 ma and be around 30 lumens.
flame2000
(flame2000)
October 27, 2012, 2:32pm
100
Thanks a lot!
I guess 30 lumens is emitter lumen since 70mA is 5% of 1400mA.
I’m still deciding whether to pop a KD 7135 V2 driver into this light or not? Would prefer a lower low but I read that the KD 7135 V2 driver low is extremely low ~0.7 lumen.
I hardly used 0.2 lumen on my Zebralight SC51. Most of the time I used the 2.5 lumen.
scaru
(scaru)
October 27, 2012, 2:35pm
101
Yeah, emitter lumens (actually it was around 29) so probably around 15-20 OTF.
This is one of my favorite this about this site, you get to pick what you want a lot of the times.
Okee
(Okee)
October 30, 2012, 8:28pm
103
Will this light run on 2 CR123A batteries? And how about 2 RCR123A batteries?
NightCrawl
(NightCrawl)
October 30, 2012, 8:59pm
104
Maybe and no. Those drivers sometimes can handle 6V without burning, but I wouldnt bet on it.
So short:
No and no.
mfpmax
(mfpmax)
November 18, 2012, 1:47pm
105
Anyone know what size switch is used? Looking at making one a forward clicky
BIGWOOD
(BIGWOOD)
November 18, 2012, 7:28pm
106
PCB dia. 20mm
switch itself is 12 x 12mm if you want to re-use the plastic switch retainer
mfpmax
(mfpmax)
November 18, 2012, 10:35pm
107
Thank you very much…now to pick an emitter LOL
kahvitahra
(kahvitahra)
November 23, 2012, 9:33pm
108
I bought this EDC 18650 flashlight host and powered it up with U3 1C LED + AMC7135*8 nanjg 105c . Really good set up. Gives much of flood for such a small host. Gets hot pretty fast on hight thought. That dosen’t bother me ’cause I use it short periouds of time and really need those lumens in these dark days :). Good EDC for me!
Here’s one beamshot.
Tree is about 45m away.
http://oi46.tinypic.com/1zv4f9y.jpg
