I haven't done much on these lights yet, but I did manage a couple of videos. One is on where to cut the body of a 2D, if you are doing the human lathe method, with a tail cap switch. The other has a little information about a "D" Maglite switch and modding it.
This is just one example and it has two seams. It can be done with one seam, by cutting at (from the top) 40mm and 110mm. Then you end up with the knurl closer to the head, but only one seam. Of course, for a shorty that uses the stock switch, the measurements will be different again.
This video is on the newer style tail cap switch I've been doing. It's different from the old one, so I thought I would show how it's done.
BEAM SHOTS
ISO 100, F:2.7, Daylight WB, Shutter 1 second.
Here's the 2AAA light against the garage door. I don't know what degree the TIR optic is, but it's a total flooder.
Here is the 2AA light and I have a MOUSE OVER for the two TIR optics. The first photo (mouse out), is the 15 degree optic. The second photo (mouse over), is the 45 degree optic.
I have done mouse overs on the 1D reflectors as well.
Here, the first photo (mouse out) is the shorter of the two CNQG reflectors I use. The second photo (mouse over), is the deep reflector from CNQG that I use. The short reflector is 51.2mmX29.5mm and the deep reflector is 52mmX40mm. The next shots show you that the short reflector is a tighter thrower than the deep one? Maybe It's not the depth, it's the diameter and the actual reflector profile.
I took the shutter speed to 1/15 second, to show a better shot of the actual hot spot on both the reflectors for the 1D. The first photo (mouse out), is the shallow reflector and the second photo (mouse over), is the deep reflector.
These next two shots are done with 2 seconds shutter speed. The images are not zoomed in, but merely cropped. The distance is around 80+ yards. This is with the Shallow reflector, which has a tighter hot spot than the deep reflector.
OH, here's a shot of the two TIR optics for the 2AA light
That's it. The set of three will go up for sale soon.
