How?
YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
How?
The physical switch looks to be a standard momentary switch as used in all types of consumer electronics, depending on the driver just add a latching state.
To change mode you have to change the Circuit Board first ,such as this one .And as to choose the circuit board ,you have to know the diameter of your flashlight .Can you tell me your flashlight model?maybe I can help you
As per the title, SkyRay King
Input max 4.3V 12Ah
Output 7.5-12Ah
Modes required, 100%
Modes desired, 5, 25, 75%.
I would ideally like:
Direct Drive dropping to 9Ah after a short time, then 6Ah, 3Ah, 1.5Ah then moonlight mode with almost nothing.
A guy can dream right?
How big would the board need to be? 50mm?
Would you please post a picture of your flashlight ,so that I can decide the diameter of the board
Google Sky Ray King.
I do not have the light.
The Sky Ray King is essentially the same light that you sell under a different name here: http://www.lightscastle.com/product/fandyfire-uv-s5-cree-xm-l-t6-3-mode-3000lm-3-led-white-flashlight-w-strap—yellow-4-x-18650-130032
I’m currently working on a King driver mod, unfortunately I don’t have much spare time currently… I’ll post results when I’m done (if I succeed, that is), may take some weeks.
As per the title, SkyRay King Input max 4.3V 12Ah Output 7.5-12Ah Modes required, 100% Modes desired, 5%, 25%, 75%. I would ideally like: Direct Drive dropping to 9Ah after a short time, then 6Ah, 3Ah, 1.5Ah then moonlight mode with almost nothing. A guy can dream right? How big would the board need to be? 50mm?
Maybe you will want to rethink about the spacing values for the modes: output is not linear with current, with your amperages I feel you will end up with 4 very bright modes, very close to eachother, and no real low.
For example, a light that I like a lot for the spacing between modes and good low, is the Lumapower Dmini-VX, and it has 2,5A - 0,50A - 0,12A - 0,02A
Weeks!!! You have 7 days J)
You may very well be right, I haven’t done a lot of research into it.
It wouldn’t be a straight up driver swap. The King uses an e-switch that doesn’t rely on power interrupt to turn off or mode flip. So the mode control EPROM of the circuit never really completely powers off. AFIAK no one makes a drop-in replacement driver that uses an e-switch.
Likewise, modding it to 3S or 4S 18650 would require a lot of DIY fabrication too, at both the + and - end. You would have to effectively isolate the cells from the - tailcap end and from the + head, and in place of the “P” connection wire everything up for series cells. Definitely an advanced mod, for a builder with some serious DIY fabrication skills.
Add a small latching circuit, I assume there is voltage at the switch. Shouldn’t be too hard to do.
It might be easier to re-program the EPROM. Its been done before on other lights, both on CPF and BLF. No one has attempted it on a SR King though.
A latching circuit looks something like this
I have EEPROM readers, when mine comes I will give it a go.
Cool… keep us updated on how that goes. You should also kill the low PWM while you are at it. IIRC its in the vicinity of ~100-130 Hz which is way too low for almost everyone.
If anyone has a picture of the EEPROM in the driver board it will be a start.
viw, see this thread for some nice high res pictures of it.
Did you post this from m.phone or tablet?
I am waiting until someone finally find the way to change this stupid modes (hi-lo-strobe) and then I’ll get the King :- )
Hope to insert DrJones’s ramping sw :- )
