Sorry I'm wrong it's metal
Maybe it's some Chinese newly invented alloy which is made from aluminum and plastic combined. Some people are seeing it as plastic, while others see it as aluminum but it's really the same. :) Just a thought.
-Garry
It's very hard to tell at first. I scraped a little finish off the lip edge with a knife, colored plastic below.
Well that sounds to me like a good quality plastic reflector - one that's very hard to tell it's plastic. I don't mind plastic reflectors when their decent quality.
-Garry
No, viffer's one is definitely aluminium. There are two variants here.
What I'm trying to establish is whether DX is selling out aluminium and Manafont using plastic, OR whether it's just lottery luck no matter where you order.
It would help members to choose where they will purchase which variant. I'd go with alu anytime, maybe they're the same reflecting quality but there's a big difference in heatsinking.
If I remember, I believe viffer got his from Manafont and so did BetweenRides (who has plastic as stated above) and myself (not yet determined plastic or aluminum).
-Garry
Mine came from manafont and is plastic, good quality plastic, but plastic none the less.
I think we’re on the second manufacturing batch as we all seem to be picking up assembly issues that are not apparent in olds review example.
I also wouldn’t worry about heat sinking, that’s covered with the pill size and connection to the head.
Both the Small Sun ZY-T13 and ZY-T16 have aluminium reflector in the desscription but the ZY-T08 description does not state whether it's aluminium or plastic on the Manafont website
DX specifically put "aluminium smooth reflector" in the description. Manafont does not mention the type.
Hopefully with some more input we can establish the baseline.
So, please help out, who bought from where and got what type reflector?
Yeah, true, but it's a plus nevertheless. I've got noticeably slower heat sags on my aluminium-reflector lights compared to plastic ones.
I don't remember hearing from anyone who bought it from DX, but I bet there is someone (or a few).
Maybe gords just needs to order another one or two and see what he gets. :) He likes to order lots of lights.
-Garry
Cough splutter what? I can hide one zy-t08, three or four might get me a right good kick in the nuts! :*
I see you quoted me before I got your name edited - sorry about that! I fixed it now. (It was that darn "multiple posts within 1 minute" issue and I got distracted.)
-Garry
No worries Gary I know who you were stitching up meant. :bigsmile:
Something I learned when I was a kid… When its too difficult to distinguish if something is metal or plastic… just lightly tap it against your tooth and you’ll be able to tell. Kind of like how you would check if a pearl is real or plastic. I know it sounds silly, but thats what used to work for me. I’d open up my T08, but I’m happy with the way mine is right now, and I dont want to open it up and do something stupid to ruin it.
I’ve been following this thread, and so close to ordering, but I think I’ll wait until we hear more about aluminum/plastic.
although, I’m thinking about modding this light anyway…so maybe it won’t matter.
could someone measure the diameter of the lens, and the height of the reflector?
also, i’m wondering about the “second version” that Garry and Dr. Jones mentioned - is there a similar light with different head and tail switch? If they’re interchangeable I might have to lego them to use luxdrv
There’s so much space in the pill, you could use the original driver board as a power board, and throw a 17mm driver in there, honestly, its about 30mm across and about 60mm deep with 4mm thick walls! You’d need about 6 ounces of fujik to pot the bugger! Hence my comment on a copper slug with a u2/3 bonded to it.
Mine has also plastic reflector, just checked out. Ordered from Manafont.
Probably for this reason, reflector is not as smooth as aluminum ones in my other lights. Pretty ringy beam around hotspot.
Could it also be one reason for lowish output / throw?
Pill and driver get loose very easily, and can lead to connection failures.
All in all, I think this is far worse in build quality compared to Smallsun ZY-T13.
Got mine from Manafont and it's plastic. Overall, mine is a very well put together light. I just had to tighten the pill, otherwise no blemishes, everything's centered and it performs. Not planning on taking it apart again. For the price, this was a great purchase.
