than me could explain it better, but essentially it’s their construction. Screw-in pills, EZ900 XRE’s, really nice aluminum reflectors, nice machining, anodizing, solid-brass flat machined surfaced tail-cap negative spring contacts, glass lenses, nice tight hot spot, throws plenty well, all in all for when they were at $7.69, well kinda an unbeatable thing. I hope they go back on sale again.
The only thing I don’t like about them is next memory 5-mode. But I just take care of that by solder-bridging the C1 Capacitor to make it just one-mode. I think Pulsar13 solders on a 1 megaohm resister over said C1 and he shortens the going back to high after shut off to the tune of just 3 secs.
Xintd c8 v3, there’s just something for everyone
Hd2010
Skyray king.
Also rans include the edc18650 from intl outdoor, the small sun zy-t08 which is a victim of its own popularity and the eagletac dc25 clicky seems to be gaining a lot of attention, at the prices I’ve seen though, its not budget to my mind.
As far as I can ferret out, yeah he’s the only one although one would surmise his maker is most likely supplying it to other sellers. But who knows. Maybe he has an exclusive arrangement with a small shop. I say small because my hunch is that the QC is too good on these to be a big maker who has a lot of different workers with varying skill levels. I think the shop prolly has relative few people and they’re able to keep the quality consistency up as a result. Just a hunch.
The tip-offs are these ‘different’ markings on the tube.
1). His units have, ‘HWA/WTS’. Most C8 clones have ‘HWA/WYS’.
2). UltraFire has the flames all solid white, and the “Registered” or R with a circle around it is also up by the flames instead of typically down by the ‘e’ in ‘fire’.
3). Lastly, it’s real subtle but on the tube again next to ‘CREE’ you’ll see the double-diamond symbols. His have the first diamond with black stripes with a white background and a solid thicker black line in the middle, with the backgrounnd or overlaid quarter-diamond being solid white. If you note on other clones they don’t quite match to his unique markings.
Small Sun ZY-T08
L3 Illumination K40(may not be budget to some, but for what you get for $108 shipped is pure quality and super brightness and throw all in one package)
TK35 clone
For me, it's gotta be the L2M because it's not just one flashlight . . .
For gifting, $11 isn't as cheap as the L2i used to be but the L2M offers a lot of versatility/Legobility. Someone would think you spent more than you did when they feel this hefty guy in their hand.
Balder HD-1? Really?
I was going to purchase BUT:
An online search and review indicated some with piston/switching problems.
I’m sure they can be remedied, but that’s the price one sometimes has to pay for the First Version of any newcomer to the market.
I’ll wait a while on this one.
Since it has not been mentioned here yet…
Have to nominate the UniqueFire UF-V3 CREE-U2.
I’m quite pleased with the one I got from Tmart for $17.87 delivered.
Only pushing just over 2 amps but a nice clean beam profile and good throw.
Nice compact build quality for the price.
Flood - King. Just an awesome mix of portability, runtime, regulation (old driver), safety (parallel), and of course, lumens lumens lumens! Nobody I showed this to wasn't surprised. Only weakness is in UI (which will be solved soon by our good doctor).
Throw - ZY-T13. So easy to modify for extra current. 60+ mm aluminium reflector, add dedome and get hotspot as tight as any good XR-E thrower at 5m. Throws 500m tested (0.22ohm resistor mod, dedomed), not even at the limit. Excellent UI with mode-switch button, instant on forward clicky (always start High) which is a blessing for this thrower. Very good constant power regulation. And of course, $24!!!
Lower-budget lights - C8 copy (like lumatic mentioned) really deserve a mention. You cannot go wrong at $7 and change. But I cannot nominate this since there is no dedicated maker/trusted shop - ebay has too many variants around.
BLF Mini would have made the list for EDC but mine is really screwed up - it actually has random mode start now. And keep skipping modes. So I haven't really experienced the UI in real life testing - cannot nominate.
On mine , it seems directly related to the Oring , remove it from the piston , and it seems to work great ...
Unfortunately , to test I put another O ring on the piston , now its a little iffy again ..
So on my sample , the piston issue seems to be relates to the fit of the Oring = Too tight a fit in the body = iffy switch / remove the Oring , and it works fine ...
That’s too bad. I would have hoped Balder could come up with a fix. You would think so. If they are aware of it, which I’m almost sure they must be, it’s sort of a black eye for them. Come on Balder. Fix it. I’d love one.
Too thin an Oring , and the Oring can break - original broke rather quickly - My fault ...
Replacement was a little thicker , and now the switch is a little iffy [ shutting off ] Sometimes , you need to hold down the plunger for like 10 seconds for the light to turn off , and all because of the Oring ..
Been super busy with school , and even with only one day of programming to go , the teacher is pilling it on , and adding work to the assignments [ end of year assignments ] , which is adding to the work load ...
So Im up till like midnight doing home work , trying to keep on top of the situation almost every night . [ kind of stressful ]
Even yesterday he put more on the plate - So I kind of pointed out that the last day was Thursday , so now , we have till Sunday evening to complete the assignments , even though programming classes end Thu - oooh dear! , there goes another week end ! I havent had a week end for a month or so ....
