10440's
thanks for your interest guys! the self-discharge test for the 1 blue cell is still ongoing since i dont need it. i use the grey protected in my Tank E09 and the blue unprotected in my LD01. i hardly use my ITP A3 anymore and i would feed the identical blue unprotected. that's how i can continue to measure the remaining offline voltage of the 2nd cell (which i had marked with a red Sharpie/Edding).
the grey protected cells seem to hold the charge much better than the blue unprotected ones but it doesnt make sense to do self-discharge tests with them because i use them all the time (aged cells!) and it takes only ~50mins to recharge a completely drained 10440 cell (they typically hold 320-350mAh capacity).
as a general statement we could say that 10440's drop in remaining offline voltage at a higher pace than the bigger round cells (14500, 18650, ..), which was to be expected, but that's no big problem because recharging 10440's takes only 50mins (with the 300mA charge rate setting of the WF-188).
Very much appreciate your solid efforts!
You didnt measure load voltage there. Load voltage could be anywhere between 0.1V lower or 1V lower.
Wow, food for thought. I have bunch of the old blue 10440’s . I use them all the time in applications
that were never intended to get such a kick in the A—…-. Does the same apply to 14500’s , in general terms?
Think I should share this information from my pm with kreisler.
(I have reformatted the pm and removed some other unrelated content.)
I saw the bottom of kreisler’s post.
“UltraFire Gray Protected red marked cell 254mAh-0.1A (repeated tests: 261mAh, 260mAh), or: typical if not charged fully to 4.200V: 245mAh) UltraFire Gray Protected *unmarked cell* 225mAh–0.1A, rest offline voltage 3.3V (repeated test: 229mAh)”
What is does it mean by red marked cell and unmarked cell?
remember i bought a PAIR of cells?
it is to distinguish one cell from the other.
i use a marker to mark one cell.
Thanks for sharing the PMs. Now everybody can see that kreisl is a nice guy helping fellow boardies in need ftw. i am the best!!
hehe..
How we do say here, no tienes abuela, eh? :stuck_out_tongue:
What does that mean? From my meager understanding of Spanish "you don't have a grandmother eh?"
Hi scaru
Yes, that is. If you don’t have a grandmother you need someone else (kreisler itself!) to do compliments / praise / be kind on yourself.
Thanks. :)
Couldnt figure that one out so I went to google translate. Does that mean "praise own shit safe"?
more like: Own praise, sure shit
There are 2 more options for protected 10440 which might get popular.
Hope there will be reviews for the batteries soon somewhere.
They could be identical or clones of those mentioned in the OP.
The protruding nub of the ultrafire one looks different as it looks smooth in the third picture on the site.
blue ultrafire 600mah
http://www.fasttech.com/products/1420/10000930/1078100-ultrafire-10440-36v-600mah-protected-rechargeable-
black trustfire 600mah
http://www.fasttech.com/products/1420/10000933/1078108-trustfire-10440-37v-600mah-protected-rechargeable-
I have bought the Trustfire blacks.
Hi there BLFiers!
How2, have you got an iTP A3 by any chance to check them?
Very nice ! reminds me to check my 10440's , must be about a year or so since charging the one in my Maratac ..
Wow - 4.04 volts , and its been sitting in a drawer for about a year
No I want to buy the Ultrafire UF-T1
I cant vouch for the current crop of chargers , but the GTL charger is some what low current
for smaller batteries .
Ooops , thats the wrong way to do it ! - Been 2 years since testing charger ! damn .... Ok the right way now ..........
Ok , this is the right way to do it !
Where was I , thats right , the GTL charges at about 300mAh , now I cant vouch for the current crop of chargers
as this one is over 2 years old . But if you want a low current charger , more suited to 16340 - 14500 and 10440
then you may wish to cinsider a GTL charger [ cant beleive I said that ] , the quality is ??
