Uniquefire AA-S1 + NGJ-18
4 posts / 0 new
angusinalberta
Last seen: 10 years 7 months ago
The Uniquefire AA-S1 is a very nice single mode AA light. If you decide you want to convert it into a multimode light you quickly find that it's hard to find an appropriate driver that will fit into the 14.7 mm space.
Fortunately miguelmoreto has already descibed [1] how to easily squeeze a 17 mm board into a Trustfire F20 by removing a brass ring used for making the ground connection. His instrucions work almost perfectly.
The brass ring was pressed in too tightly to be pried out so instead I used a small dremel tool to cut the ring, after which it slid out easily. I am keeping the ring in the event I ever want to revert to the old board.
I chose the NJG-18 for two reasons. First, one of its programmed groups has mode of low-med-high with no disco modes. Second, the output voltage is adjustable. That I thought might be an important feature, in that the Vf of the Osram emitter is 2.4 V and most drivers seem to be designed for the higher Vf of Cree emitters.
The battery current for different settings of the adjustment potentiometer follow.
njg
With the pot set at 1/8 turn ccw (-1 on the graph) the output at 1.00 m is 77 lx, 420 lx and 810 lx. The maximum output is slightly lower compared to what I measured with the original driver, ~950 lx.
Note that with the pot set to 2/8 ccw (-2 on the graph) it refuses to go into high mode.
All in all I'm even happier with the AA-S1 than before. I normally use low mode around the house, which should result in about 18 h battery life. The high mode is just as bright to my eye as before.
All those nasty blink modes are still a trap for the unwary. The 12f629 is asking to be reprogrammed next.
[1] http://sites.google.com/site/miguelmoreto/home-eng/projects
Cheers,
Angus
Match
Match's picture
Last seen: 5 years 7 months ago
Nice mod, Angus.  I haven't had a chance to play with that particular driver yet, only read about it.  Looks like DX is out of stock on them, but a place here stateside has them (e-lectronics.net).  Looks like you can adjust the pot for a really low low.
Again, nice mod!
angusinalberta
Thanks for your comments, Match.
I'm looking forward to hearing about your experiences with the NJG-18 in the future. It promises to be an ideal universal board for driving most anything.
In the meantime I'm still puzzled why mine can't get above 1.3 A input on a single AA. More than likely just a dodgy ground connection to the body. On the DX forum they're reporting over 1 A to the emitter.
I'll post new results if anything changes after I clean up the connection.
Cheers,
Angus
angusinalberta
After re-doing the ground connection, the battery current is now 1.88 A at 2/8 ccw on the pot.
Lux at 1.00 m:  low 109, medium 420, high 1248
Or in terms of throw: low 10 m, medium  20 m, high 35 m (using the square root rule)
This is the new graph.mod
At 3 eighths of a turn ccw the high current remains at 1.7 A, the same as medium.
For the next day or 2 I'll leave it set at -2 before reverting back to -1 or maybe even 0 for better battery life.
Cheers
Angus
