I bought two more. You better get CC working right quick! If you're lucky you might get a regular 3-mode version but the 4-group versions are going to disappear pronto.
There is now three less. Hopefully I will have a light up and running today with one I bought when they first came out not knowing they were a bag of tricks.
Two less now, I couldn’t pass them up, their just too good.
I can afford one, if I quit sodas for a couple of daze… J) I actually ordered one last night…along with a U3, 1C bin
Anyone else coming across the 3 lumen output? I know it happens in my light because of a bad switch but the fact that it happens gives me hope that it’s a really, really hidden mode
I've just run this driver on three AAA Turnigy LSD nimh batteries out of curiosity. The battery holder was cheap and nasty. Starting current at the tailcap was 1.6 amps with the drver on high. I turned the flashlight off after 45 minutes as the light output had considerably dulled.
You have PM Hank
There is a really low output with a current draw of 10mA (probably around 2 lumens) which I sometimes get by fiddling with the switch however, this is not a mode option that can be chosen at any given time.
On my driver to select the really low output, if the light is in the high, medium, low, mode, put the light on low, after it flashes 3 times quickly turn the light on and off fast and it will be in really low mode.
That sounds like the start of ramping mode, the low is real real low. This is what I like, I can go from sleeping child friendly to eye seering, lock in the brightness I want, and it’d there through battery changes, till I decide to change it, it really is awesome. 8)
No, on mine its definitely a separate low low mode. its lower than any other low and you can turn it on and of as many times as you like and it stays in this mode until you want to change it.
MRsDNF. You actually get it on the low, low every time you try the trick? I haven’t been able to find a consistent way to get to that mode except by fiddling with the switch (from any output). With my T5 LED, the output is just about 3 lumens.
If I'm quick enough after the three flashes on low or maybe gords is right. It may be the start of ramping low?
It’s not the start of ramping. When I get home, I’ll try your method and see if it works every time. That’ll be great!!
I’m highly tempted to buy this driver for my CQG extreme runtime host, but the PWM is bothering me… Has anyone measured the PWM frequency?
Thanks in advance!
The, I’ll try and measure it when I get home, based on looking at 1250rpm fan, its pretty high though.
Thanks gords!
the There is deffinite PWM that is slower than that of the nanjg drivers but, it’s not so bad that I constantly notice it. If the host has space would adding a capacitor to the output be an option for you?
I’ve lost my low, low mode:(( Ok. so I changed hosts from a 2D mag to a 3C mag and I’ve been unable to find that low, low mode MRsDNF also discovered. so sad.
Hi the I couldn’t get a frequency reading at the star sorry, it is quite high though, if I get chance today or tomorrow I’ll see if I can video a fan under the light if that helps?
Hi, hopefully this works, this should be a video showing a lowish part of the 4a driver, then the blf a8 as a comparison.
Hope it helps some.
<a href=Photo Storage target=_blank><img src=http://static.photobucket.com/player.swf?file=http://vid185.photobucket.com/albums/x48/gords1001/VIDEO0021.mp4 border=0 alt=>
