What site for the uf-980l ?
Thanks Dave.
Thanks Dave.
Its a bonus that manafont seems to be one of the best places to order budget lights from!
yes Manafont is an amazing place and ships so fast..never thought it was possible from a hk dealer..i'll have a review of the 980l soon enough when I get some free time to get a beamshot or 2..but for a thrower with xml I have not seen any better than the 980l..
Ultimate thrower: Brinyte XML-C5
5,5-6,5cm deep reflector!
But unfortunately it´s a 1-mode and i don´t know anything about the driver in this flashlight.
(i have the same with 3-mode driver(selfbuild))
One of the reasons I am considering one of the 3 flashlights mentoned above is DX claims 3000 ma output and the other is that they are rated at 1200 lm.
How does the 980l and Brinyte compare in output? I realize that you never know what you're gona get from china and seeing is believing.
I do realize that they lie there a$$e$ off about LM's is this also the true with output?
Thank's guys for letting me pick your brains and for all the helpfull info.
Output should be near the same (with XML driver).
The reflector of the 980l looks like, it has the same deep like e.g. C8 (42x33mm).....Brinyte´s has ~double deep. (much more throw)
So ugly though! the hex "nut" appearance just annoys me, If the head was simpler, id be having those in my collection.
Indeed i kind of dislike hard the plumbing tube look.
the 980l drives the xml at 4.6a on certain low resistance cells I have..others it's 3.8a and so on..I use the higher resistance cells to lower the amperage draw for led longevity..you can't drive this led any harder without hurting it so the 980l is as bright as the xmls can get..someone correct me if i'm wrong?
here's a crappy phone pic to show you the beam profile of the 980l..this is on medium (1.2a) i'll have a review this weekend when i'm not working..
XM-L best drives at 3,5A.
From 3,5A - 4A it´s not really brighter and over 4A it´s only hotter.
(my Brinyte C5 drives 5,14A with full charged 18650, little bit too much)
edit: ah, the 980l and my Brinyte maybe have the same driver. the driver of 980l look´s like the ultrafire xml-dropin driver.....and this driver is now in my Brinyte.
exactly why I use the higher rersistance cells..I have a couple that will allow a 4.6a draw and I label those so I don't use them in this light..
I don't mind the that it's 1-mode.
Any experience with the Brinyte xml-900 2-18650 at DX ? Is this one also a thrower?
The Ultrafire nh-t60 looks like a possiable thrower.
I am not going to order any more flashlights without without a thumbs up from BLF members.
So what do ya think brinyte xml-900 thumbs up or down?
Thanks for the help.
The Brinyte xml-900 & Ultrafire nh-t60 has not a deep reflector, i think, both reflectors are C8 similar (in deep ~33mm).
So, Brinyte C5 XML throws wider.
p.s. the hotspot and spill is much less, than my other XML lights, but the spill of the Brinyte "delete" the spill of all my other flashlights.
yep they look identical to the 3 mode uf drop in at manafont..pretty nasty driver i'd hate to see the current draw on an IMR cell..
Thanks Andi and Pounder for all the usefull information. Now I see there is a cree xml u2 1300 lm at KD. Not much info on it I am assuming it isn't a thrower either?
Looks like i'll try the Brinyte 1-mode.
Yes, for Throw, i think, the Brinyte is best.
I hope, the driver delivers the needed mA for a XML.
Review of the Brinyte with Q5 LED: HERE (unfortunately only in german)
WOW!!! I see what you mean. Nice throw!
The pics help to see how big the reflector realy is.
Thanks can't wait to get one.
Found good pictures of the reflector: @DX
...besides, the Brinyte D8 is the successor of the Brinyte C5, reflector has same deep, but it´s little bit wider. (little bit more spill and little bit less throw)
Review: HERE
Can be buy with XML: HERE (but found only a shop in germany, there it´s a little bit more expensive ;) )
still....the Brinyte C5 throws wider ;)
Thanks Andi...
You convinced me I ordered the c5 along with some free lights. Not at all sure about that though?
I will let you know how it works out.
ok ;)
I hope your leads will give correct measures, because i think 70% of the mA measures are not correctly ;)
