You are referring to the new version - it uses a different driver, allowing the user to change modes via the UI with no need for soldering. Choice is just 2 modes now, but can be switched on the fly. Haven't done it myself, but what they are saying is switch the light to low, turn it off. When turned on, it will come up in low mode, then in 3 secs it will blink once - very quickly then turn it off then on -- this should change modes. If you don't see the 3 sec blink, you probably have the older EDC driver which is soldered in place.
It means it will blink every single time if I leave in low mode And if I turn it off then, it will go in to strobe mode. Aaaarrrrggg, I hate this. Why can’t they leave a good three mode with memory alone? If they wanted to add the strobe, make it so that it will be almost impossible to accidentally enter in to it e.g. fast click 6 times in 2 seconds or something like that before switching in to strobe mode.
Even though mine had the old 105c driver, I changed it to the KD V2 driver. Mine is set up L-M-H-L-M-H-strobe-SOS with no memory. And it has memory or no memory option. I am thinking about buying another one and will just buy the host and build it like I want.
That’s right about changing from 3 to 5 mode, it doesn’t switch quite that easily. Took me a few tries to get 5 mode, then a few tries again back to 3 mode. It takes 3 quick on/off or something to switch. Dunno, was glad it went back to 3 mode, and it’ll likely stay there. The off/on flash in low mode is a bit surprising/annoying every time, might take getting used to.
I only have 5-6 different lights, this one I’ve had only a week or so, but it’s one of my favorites…. size, brightness, floody…
I bought two of these, one black with XM-L U2, and one gold with XP-G2. They’re very nice. However, the XP-G2 one has had some mode and switch issues ever since it arrived.
Sometimes it’ll turn on and operate normally. Sometimes it’ll blink quickly then turn off, or not turn on at all. Sometimes it’ll turn on and flicker at several different brightnesses without being touched. Sometimes on low it’ll blink off briefly every second or two. And when changing modes with a half-press, it’ll often rotate two or three levels per press, flicker as if shorting, or otherwise behave strangely. It seems like something inside must be cracked or shorting or otherwise damaged.
Any idea if a new switch would help, or is this more likely an issue in some other component?
2. Both of my EDC 18650 lights have PWM on medium and low. However, it flashes so fast I can barely see it. It’s faster than my iTP A3 EOS (final rev), which selfbuilt measured at 2.45 kHz, so I’d guess it’s at least 3 kHz. (and yes, I can see that) It’s much much nicer than the common 200 Hz PWM, and most people probably won’t notice it at all.
4. I added a SolarForce L2 clip to both of mine, and it works great! However, you must add a small spacer in the tailcap to make it contact the non-anodized part of the body. A standard paperclip works pretty well for this, if you can find just the right thickness.
(BTW, the switch/mode issues on one of my units was there before adding a clip; it’s not caused by the spacer)
It still makes a difference in terms of efficiency and beam tint though, as well as how motion looks. I think the only torch I have with true current-regulated constant output is my Zebralight.
If it’s really 4.5 kHz, I’m a little disturbed that I can still see it. That sort of frequency should be heard, not seen…
Efficiency is slightly worse, but no tint shift. I can't see any PWM against computer fan. Do you have older driver with stars or newer 3/5 mode? I have old one.
I really really like these drivers for an edc, I have the option of the flashy modes if I need them, it has true memory, and they are current controlled on all levels, since much of my work involves fans and engines, its nice not seeing things strobing in lower modes. Pwm doesn’t bother me, but its still nice to have it eliminated and in this size of host, 2.6a is all you really need going to an xm-l, 2a is overkill on an xp-g but they accept it, and give a nice amount of throw.
Personally, I’d now try to get the 2 series of both xm-l and xp-g, as they are not so expensive and give higher output for the same input, but I don’t believe anyone would be unhappy with the older emitters, tint wise, I’m liking the 4c tint in xp-g and 3c tint in xm-l is acceptable, I still need to try an xm-l 4c.
It should also be noted, fasttech is keeping the convoy series of lights in a huge selection of drive currents and tints. I love intloutdoor, and tend to order there over anywhere else, but fasttech’s pricing is hard to ignore.
I have a 3/5 mode XM-L and 3-mode-only XP-G2. The 3/5 mode one is nice, aside from the mandatory blink on low. However, that’s not so bad, and it verifies to me each time that I’m on the level I expected. It’s nice to have the option of flash/SOS without having it in the main sequence when I don’t want it.
Thanks. I don’t really see any problem with what I’ve got now though, aside from some flaky behavior on one of the lights. The PWM doesn’t bother me, even though I can see it. That link does explain one of the weird behaviors I’ve seen though… sometimes my XP-G2 light will turn on at low then blink off quickly every second or two. It seems this is the driver’s response to low voltage. Something inside apparently isn’t connecting reliably.
What I don’t know yet is whether this is caused by the switch, the driver, or some other component.
I finally got my EDC 18650. It’s a black one with the convoy s3 marking. It isn’t as bright as I expected for around 700 lumens since it seems to be around as bright as my PD30.
I ordered one with the XM-L U2, is there any way to tell if I got what I ordered? Thanks.
