Tint, Binning, and CRI Explained (For XM-L LEDs)
So far there aren't any, (I'll change that example) but a XM-L2 T6 3C would be equivalent to a XM-L U3 3C.
Subscribed! Thank you for the chart scaru!
If they left off the phosphor completely, how high would the bin be, and what shade of blue?
It would be just like their blue XM-L series, at approximately 450-465nm.
The colored versions of XM-L’s are here: http://www.cree.com/led-components-and-modules/products/xlamp/arrays-directional/xlamp-xml-color
I don’t think they have color bins though.
I truthfully do not know, I can tell you when I have taken the phosphor off the LED in the past (while dedoming) it becomes a deep blue.
Based on that chart, I would say it was around 8000k. (general estimate)
Edit:
As ryan pointed out, their blue XM-L is 450-465 nm so it would be a royal blue.
However, for what ever reason it seems that the blue LED in their colored XM-L is much less efficient than a white one. So now I am doubting myself. :( The white die produces 100 lumens at 350 mah and the blue one produces 13.9 lumens at 350 mah.
http://www.cree.com/led-components-and-modules/products/xlamp/arrays-directional/~/media/Files/Cree/LED%20Components%20and%20Modules/XLamp/Data%20and%20Binning/XLampXML_Color.pdf
Off to go do some more research, now I am wondering whether the phosphor is needed to convert it to light in the visible spectrum.
nice run through scaru. Only niggle is that CW Cree LEDs are generally 65CRI, although the newer XM-L2 CW seem to be 70CRI. NW and warmer are 75CRI, one reason so many people like them over CW :slight_smile:
Added to the mod reference guide, this is brilliant, thanks scaru. 8)
Just changed it! Thanks. :)
This is what you’re looking for:
XM-L2 T6 5000k NW
Added a list of links to buy different XM-Ls based on tint.
Thanks for the link.
Mouser’s shipping is $20 for an $8 LED, so I think I’ll wait for FastTech to stock them. :slight_smile:
Thanks scaru for the effort. I understand simple.
Thanks scaru! I vote that this should be stickied…
Thank you scaru! Very well written. Nice reference and links!
Thank you
Thanks a lot for doing this Scaru, I like the way you put links to vendors of each of the tints available, I think this thread should be stickied
Thank you!
That’s what I don’t understand. If it is more blue and brighter the less phosphor, why are blue xml dimmer? I don’t think there is any way to “redome” an led after stripping the phosphor is there?
I doubt one could do it without losing even more light.
Just found an explanation on wikipedia.
"For example, the efficiency of a typical...yellow phosphor based white LED ranges from 3 to 5 times the efficiency of the original blue LED because of the greater luminous efficacy of yellow compared to blue light."
http://en.wikipedia.org/wiki/Light-emitting_diode#Phosphor-based_LEDs
Basically, human eyes are much more sensitive to white (or yellow) light which is the cause of all this.
http://en.wikipedia.org/wiki/Luminosity_function
The blue light produced is at 450 nm while the white light (after going through the phosphor) is around 575-600. So if you look at the graph, the human eye is very sensitive to white light, but not the blue light.
So now I understand it. :D
I do too, but its already in the one stop mod reference shop, so easy to find. :wink:
