Thanks for the detailed explanation , DrJones .
Thank you. This addresses a question I had about dedoming.
Quote
To increase luminance the TIR light needs to be reflected back to the die, thus the reflecting surface must be very near to the die. Either you remove the dome completely or you only leave a small layer (<0.5mm).
Unquote.
I had Wondered if there was a range of apparent focus/tint shift. Edit relative to the amount of dome removed.
One of the biggest problems I see here is that the surface of the blue chip is not flat, not even close to flat, so while the critical angle in a GaN:Air interface is still 24 degrees, the way the surface is photons emitted from the active layer at many angles still have a chance to escape.
EDIT: Missed the part where he mentioned this.
So that's the short version .....
Thanks Dr., very illuminating (pun not intended) , I have been thinking a lot about led optics (without being a physicist -I am a cell biologist actually-), but there is not that much written down in a way I can understand it. This read helps a lot, some things I knew, some things I suspected, some things I knew wrong, some things are new to me .
I wouldn't mind the long version sometime (illustrated and well?)
Thanks for taking the time to do this excellent article, I’m about 1/2 way through, but determined to finish it.
tabs
whoa, i missed this before, thanks for the btt, tabetha, and for the science, Dr. Jones.
I’ll be studying this before I decide whether or not to de-dome a green sst-90 J)
I want to leave this god awful country I live in!!
Sorry rant over!!
DrJones,
Which high powered LED now has the highest luminance? Is it still XR-E, or is there anything that surpasses it? The XP-G2, XP-E2, XP-C or anything else?
Also, is there any breakdown anywhere that lists the luminance of all the different LEDs, like the Cree, Nichia, Luminus, etc, so that we could look at that data and decide which LEDs we want to play with and which ones we would not?
Thanks and thank you for the article,
Justin
this doesn’t have all the data you’re looking for, and you’ve probably seen it, but anyway, a good reference
What he needs to find is the flux per mm2. I may go add that to my LED sheet.
I just did a bit of math and I think a XP-E2 would actually beat a XR-E.
XR-E=114 (max brightness at 350 ma)/.81 (area of EZ900 die)=140.7407
XP-E2=142 (max brightness at 350 ma)/1 (area of die)=142
So this means that a XP-E2 has a higher surface brightness than a XR-E.
Would it also beat an xre r2? If so does that mean it would out throw the xre r2?
Well, this shows that the XP-E2 produces more light per mm2. Of course the XP-E2 has a wider viewing angle at 110 degrees v. the 90 of the XR-E. Then you have to take into account the XP-E2's efficiency at higher currents.
You can beat the h*ll out of a XRE (heat¤t-wise that is ) without destroying it, this remains to be seen with the XPE2. In other words: what does it do at 2 Amps instead of 350mA.
Excellent post, thank you very much Dr.Jones!
Thats an effective write up! Thanks, you made leds and even etendue much more clear to me.
Thanks much for this. Great write-up!
Very Good Info.
thanks for the article, very educational. i learned a lot.
i have a question. according to your explanation, d=sqrt(I/E0)=sqrt(L*A/E0)=sqrt(L*pi*0.9 / 4*E0)D = ~ 8200 D,
throw distance is directly proportional to reflector diameter. so what is the purpose of deep reflectors such as solarforce skyline, HS-801/802 ? what do deep reflectors do?
another question. is there a limit to the throw distance-reflector diameter relationship? i mean, having a reflector infinitely big doesn’t give u infinite throw, right? at which point would the reflector size has no effect on throw distance?
