I want a powerful 18650 laser on a budget
I think so. I know it is extremely dangerous and can cause blindness so I'm gonna be extra careful.
Ok, I will refrain from pointing my laser into my ear...
Yes please do, especially when there so many other fun orifices that you can fry. J)
http://lazerer.com/ is where I brought all 3 of my non-homemade lasers. They will measure your laser before they ship it out and guarantee the power if you want.
I have a 50mW 532nm green, a 200mW 650nm red and a 1000mW 445nm blue.
I often find myself using the green even though it is the lowest power (50mW is a little weak for burning things though), the red just isn’t that visible to the eye even though it can burn stuff pretty well, and the blue is just so dangerous it’s almost not fun to play with, it is by far the most impressive though, it will also burn anything, like… anything.
The 50mW green is about half as visible as the 1000mW blue in air. The green lasers are all DPSS lasers as well so they have a really nice thin beam with great divergence, the big powerful blues (445’s) are all multi-mode diodes so they need a nice glass lens just to get the beam to not be a train wreck, beam will still be fat though.
I hope to have a 500mW+ green in the future, I can’t imagine what they must look like in real life. This thing would be absolutely sick.
I’m also looking for a laser. Probably green. How powerful can I get before it becomes dangerous. I would like to be able to play with pets and show it off a little.
Even a 5mw green one is dangerous...
Before I came here, I am also Flomotion on laserpointerforums and photonlexicon. I have a WL 1 watt 445nm, a 400mw 405nm, a 250mw 650nm, and a 450mw 532nm. They will mess you up, unless you have eye protection. Any reflection directly back into your eyes can immediately burn holes in your retina. My greenie will go straight up for over 100 miles. Even a 50mw can temporary blind a pilot on a direct hit. It is a federal offense to shine a laser at any aircraft, and as the green ones can go for miles, it is possible to hit aircraft and not be aware of it. If you want lasers, go here:
Wear Eye Protection, or go blind…really…
With remaining eye…do not look into laser. Reflections can easily cause damage as well.
Yeah, get safety glasses with the appropriate lenses for whatever wavelength laser you’re working with. Yes, that may mean you need several pairs. And you’ll need them for whomever else is standing around.
Cheap 5mW lasers are dazzling to the eye, but I suspect most of them do not have the optics to generate irradiance high enough to cause permanent damage. Remember that it is not just the output power that is a factor, it is also how much area that power is spread over. You can have a very powerful laser, but if the beam is diffuse, you won’t cook anything.
If you want the numbers, this is an excellent primer on the subject:
http://spie.org/Documents/Publications/00%20STEP%20Module%2002.pdf
All of these are pretty nice for around $40:
http://www.lazerpoint.com/sc-green-laser-pointers?minPrice=38&maxPrice=45&submit=GO&categoryId=009002&submit=GO%2CGO&sortby=pricedesc&pagesize=20&viewmode=grid
I have this one:
http://www.lazerpoint.com/p-ultrafire-200mw-1000m-532nm-green-laser-pointer-pen-set-black_2077569
It says 18650 but after they mod the flashlight body, it only will accept a 16340 or 18350.
I would like to second Lazerer. I bought my purple 100mW(~$45) from there and it is great.
Chances are that you aren’t going to be able to burn anything if you can’t focus the beam.
Also, for everyone in the US (unless things have changed) in order to legally purchase/own/import/whatever, anything over 5mW needs to have a safety lockout key.
EDIT
Forgot to add that my laser runs on either 1x16340 or 1x18650.
As in the above post, I am a laser convert to flashlights. I have been in lasers for many years, built and bought many. I would like to recommend http://o-like.com/ because, like Chinese lumens, many sellers lie about the true mw power. Example, you order a 200 mw green, and it is actually about 30 mw. So you learn the hard way. o-like tests the units before sale, and there are aways overspec. Example if you order a 400 mw 405nm, it could be 450 to 480 mw. So, just believe me, after many errors, before learning about o-like, Suzie at o-like will treat you right, and the laser will be overspec…
+1 Lazerez. All custom lasers and a super nice fella!
If someones looking for a 532nm that LPM's at +830mW shoot me a PM....I may have a 250mW 532nm as well
I was going to PM you about the 250mW, but I can’t afford to lose any body parts to the wife lol. :bigsmile:
+1 :wink:
I was tempted to get one during the Wallbuys sale but I’ve used lasers in lab settings and decided the idea of using a > 5 mW laser essentially as a toy frightens me.
If I ever met someone carrying such a strong laser, I'd immediately smack them in the face.
Another thing to remember about greens is being DPSS they almost always produce some unrated amount of IR, often at a higher mw then the actual green laser. The higher end greens will sometimes have an IR filter to block the IR but many of the cheap 5mw-50mw greens do not, so be very careful with them.
Also never look into a green laser that appears to be malfunctioning (no light), the crystal in the DPSS module can become mis-aligned and cause the laser to stop producing visible light but still be producing very high levels of dangerous IR light, you could fry your retina and not even know it until it’s too late.
The reds, blues and violets are not so much of a worry (except for the fact they can still blind you) as they are all just diode lasers and won’t produce IR (unless you have an IR laser of course :p).
Let us know if it gets through customs. The 5mw limit has been enforced in the US.
Some reading:
My hope is they won't notice it with other things. ;) I mean since it doesn't have a battery in it, then it must qualify as a part not a completed laser. :P
My fingers are crossed for you! Good luck.
