Review: Skyray King (3xXM-L - 4x18650)
How thick is the glass lens?
On the King does the Glass lens sit in front of the O ring?
Glass then lens "o"ring then reflector, can someone confirm this please?
On the black SRK, - Bezel, then glass, the O ring is behind the glass, around the reflector.
There’s another on the body, at the end of the thread.
Hello everybody, I made two videos of this flashlight, bought 42€ (56$) including shipping cost :
http://youtu.be/qLA0H-tRUWE
http://youtu.be/33A6_px1GQc
Hello, I bought Sanyo 2600mah batteries for my SkyRay King but I can't use it because they have a flat top...
Look this :
Someone has a solution to use these batteries in this flashlight please?
Thank you for your help!
Hi. Some have used magnet 1mm x 5mm +superglued around outside edges +on positive anode of your flat top battery. Otherwise, buy proper battery.
Or a drop of solder.
Thank you for your help, finally I ordered Xtar 18700 2600mah batteries.
Anyone know how waterproof these are? :D
I have one. Trying not to drop it in a especially deep puddle as yet.
Frankly speaking. I’m not too confident about the waterproofing. The threads are quite shallow on the front bezel. The glass is not tight enough to seal the front. However, I’ve not seriously tested it.
King is not waterproof. The on/off button is not water-tight, water can seep in.
Is this the only major flaw?
If I were to replace the switch with a water-tight one, would the rest of the internals be relatively safe?
I'm talking about just quickly dropping it into water and picking it back up quickly. Not diving or long-term submersion. :P
Cheers.
I wish they made a SRK for diving…it’d be a perfect dive light
I also have a question, well, two:
Given the sheer amount of lumens that it outputs, hows the throw compared to C8 thats driven at 1Amp?
Will King throw as far and will have huge-spill like hotspot or will it be much dimmer?
Also, is there a light for <50$ that is as good or even better than King regarding light output-power?
Do you mean an XR-E based C8? It may not throw further, the C8 has a big head for an XR-E, but you will be able to see a lot more in the direction you point it.
The King can be had for around $40 now, there aren’t many excuses left not to get one :wink:
Yeah, Ive read plenty to see that it looks like a great light, I might get one depending how low the price goes during Wallbuys reservation sale :D!
Yes, its XR-E based C8, driven at 1Amp :D!
Well, if things are clearly visible at 100-150 meters/yards, then Id be very interested in it :D!
Fast tech carries the Warm White version now. Looks like it is a hot sunny light!
http://www.fasttech.com/products/1601/10003058/1239701-sky-ray-king-3cree-xm-l-u2-3-mode-2500-lumen-led-f
By the way, it was published with the details below. Doesn’t seem to withstand water like the experts had mentioned here.
Details:
Press the switch for 3 seconds to enter the “Rapid” mode
Ordinary waterproof function, can be used in rainy days
Working voltage: 3.6-4.2V
Working current: 2000mA
Hi,
New on here but I’m after a light that is more a thrower for distance work. The crelant has the new u3 led and is designed as a thrower, but has less lumen output. This has maybe double the lumens, but is built more as a flood light. In reality, will there be much difference between the two? SRK is a little cheaper as well, which always helps. Any opinions welcome.
SRK is definitely more of a flooder.
And FYI throwers normally have a lower lumen count, single LED and long reflector.
Check out the TN31, that’s probably the next thrower I’m getting.
Just had a look at the TN31 and it looks fantastic, unfortunately it’s a little expensive for me. Could get 6 SRK for the price of the TN31. Is there anything else along similar lines but a little cheaper?
Guess my original question was, does the big lumens of the SRK almost cancel out the gains of a long reflector as in the crelant or thrunite.
