Hi, I would like to trade for a C8 T6 or U2. What I have to offer is an Electronic Cigarette. It takes a single 18650 battery. It’s what is called a Lava Tube clone. The one I have came from Vapor Nine. It’s variable voltage from 3 volts to 6 volts in .1 volt increments. You can also check the voltage left on the battery. I have had it a few months but I’m not using it so it might as well go. These cost about $50 or so.
If you are interested I will be glad to send you pictures.
got pix of the lava tube? know how many amps or watts its able to produce?
i can fit the pill from the 502b in the tf-r2, making it a xml t6 tf-r2. use the nanj 2.8a driver. it has a ar coated glass lens in it now also. with the driver i can set it to any mode group below that you want
Group of modes:
1st Star : Low (5) - Medium (30) - High (100%) - Strobe - SOS
2nd Star: Low (5) - High (100) - Strobe
3rd Star : Low (5) - Medium (30) - High (100%)
4th Star : Low (10) - High (100)
im not sure, but i dont think the lava tube can produce the power i want though. i use dual coil 2 ohm cartos at 6 volts right now, less under load… wanna say a little over 5v. alot of these vari volt ecigs have a wattage cutoff though
edit: is it the supernova? if so id have to use it at 5v or lower to keep protection from kicking in it seems…
