Just about all I keep for leds any more are XM-L and the Nichia. I figured to put the T6 3C in this one. 2.8A driver for the T6 and a single 7135 chip for the leds. 20 leds @20mA each = 400mA and a single chip should do about 350mA, so about 17something mA for each led. Hopefully it will work out for this.
It’s only because I bought T6 3C from China. All I could find at the price I was willing to pay, so that’s what I will put in.
I would put in a Nichia, but the new batches of the 219 that I have gotten from IS are Not warm White and I suspect, not high CIR either. They are borderline neutral to cool white and don't look like high CRI from what I can tell with my eyes.
Yes, I just got some last week. They are nothing like the original batch. I would rate them at 5700K and 85 CRI or so. Just by eye, so you know how much that is worth, but for sure, much whiter than the first batch. The last two batches have been consistently whiter, but maybe that first batch was a different bin.
I was going to power the Angel Eyes ring with one 7135 chip, but after testing it out this morning, I'm more likely to just do it direct. If I use a 7135 chip, then I am forcing amperage to the LEDs, instead of them pulling what they want. If one were to go thermal and die, then all the others would automatically see more current, but without a chip, if one goes thermal and dies, the rest would not change. They would still be requesting what they were before one died. I think, in the long run, that's the way I will go. Use a driver for the XM-L and leave the 3mm LEDs DD.
What is the current draw of all of the LED's on DD? The 7135 doesn't force current at the LED's, it's just limiting it. The only reason to use the 7135 is to set a specific amperage. If the LED's handle DD fine and pull below what the 7135 can provide, then I wouldn't bother.
