Arctic MX-2 is appreciated in the CPU world. It does not have a curing time like AS5. But as will all thermal compound greases you need pressure for the best performance.
I once thought this idea:
If you have a Copper LED star and Brass pill - maybe can use the soldering between them? It has a much better heat transferring.
I vote for toothpaste - cheap, clean and minty fresh.
I almost always lap my stars+base, then screw them down (usually 4-40 taps and screws). Thermal transfer is so good that I struggle to solder the wires onto the star. In this situation, thermal pastes are a much of a muchness - the cheap chinese stuff seems to work as well (qualitatively) as the Chomerics sample I got. However, the Chomerics stuff is much easier to apply and spreads out more evenly, so if you can sweet talk them into a sample go for that.
No idea on adhesive thermal compounds though, as I’ve never used them.
How do you lap the inside of the pill where the base of the star will sit? Usually they have a rim around the flat surface, please explain what tools do you use to lap it.
screwing the pill down is a very good way to do it. but if you have never drilled and tapped a hole i suggest you buy multiple drill bits and multiple taps and practice on similair material before you attempt working on that emitter pill. working with such small drills and taps such as 2-56 or 4-40 requires a learning curve
i cant suggest whats the best. but optimum conditions using a thermal compound is having both the mating surfaces as smooth and flat as possible. you also want as little thermal compound between those surfaces as possible. the purpose of thermal compounds is to fill in the microscopic pores and scratches. if possible, compressing the parts together to get as much unneeded compound squeezed out from between them possible would be great too
I unsolder the emitter, take a steel punch that has a flat face, set it on the pcb and hot glue it in place. sometimes I use a cordless drill to spin it slowly, some times I do it entirely by hand (takes awhile).
I use 600 grit lapping compound and then alumina, i forget the micron size but it is equivalent to 1200 grit (mixed with water or mineral oil).
like matt mentioned - it makes it difficult to solder leads to the pcb because the heat transfer is so much better. I just prop the edge up a bit w/ something in order to solder
here is how much contact a typical stock pcb has (the dark portion only)
eventually, the whole thing is dark. I scrub with a toothbrush afterwards to get alumina out. then wipe thermal grease onto is as thin as possible.
and as you can see, I just watch a movie while doing it, so it doesn’t feel like a big waste of time
I don’t work much with torches (mostly bike lights) so I couldn’t really tell you, but for lapping flat surfaces and stars I use 400>800>1000>1500>2000>Mothers Mag polish with plenty of water/ spit on the wet’n’dry, using the flat on my vise as a flat surface. You can easily feel the difference with your finger tip afterwards
To do a pill, I would probably get some wood dowel 1/2 to 1/4 the diameter of the pill and wrap the sandpaper over the end. It’ll be fiddly, but with some patience you should be able to get it smoother at least.
I would really caution using screws with small stars as the screw heads can easily interfere with the optic or reflector. I’ve never had problems with 20mm stars, but the one 16mm star I used in a recent build was a complete bear. Get the smallest flattest screws you can find if you’re going that route!
to be clear, I mate the pill and pcb when lapping, I don’t just flatten them. though judging from the pcbs I’ve lapped, even just flattening them would be a significant improvement.
If you have a copper pcb and a brass pill, soldering those together is superior to almost anything except for extremly tight lapped surfaces.. there is already a solder connection between the heat source (=LED) and the heatsink (=PCB), so adding another one to connect the PCB to a larger heatsink cant have a negative influence. On cpf I read that someone grinded down the bottom of emitters and glued them on with something really good.. I mean there is stuff with better thermal conductivity than aluminium, its just very expensive. I think it was linked in the "lets discuss heatsinking" thread.
But yes, stock PCBs have very poor connection because they are so uneven.
For P60 pills: I wouldnt mind removing the rim, havent noticed any negative effects so far.
As for lapping: I find it easier to flatten pcb and heatsink first with sandpaper and bring them to a mirror-like finish, going up to 2500 grid. Then some lapping and you are done, although its better to be good at sanding than to be bad at lapping. ;)
